Trailer wiring help - Defender Source
Old January 5th, 2014, 08:27 PM
sro
Sam Odio
2008 LR2
Trailer wiring help
I'm trying to wire up a 7 pin plug on my defender (to hook up a new 16" airstream trailer).
Looking back there I found this plug with 7 wires coming out of it. It was connected to a trailer module which was then connected to a 4 ping plug.
I'm wondering - can I just wire my 7 pin plug directly to these 7 wires? All the colors match up. I don't want to short anything out so I thought I'd ask first.
ID:	87366   Click image for larger version
Name:	Screenshot 2014-01-05 17.24.15.jpg
ID:	87368   Click image for larger version
Name:	Screenshot 2014-01-05 17.24.38.png
Old January 5th, 2014, 08:30 PM
sro
Sam Odio
2008 LR2
Also, while I was in there, I saw these two wires just hanging not connected to anything. Anyone know what they might be?
Old January 6th, 2014, 01:28 PM
sro
Sam Odio
2008 LR2
Any help? Can someone at least tell me whether this is aftermarket or a standard plug?
Old January 6th, 2014, 01:37 PM
I am not sure what connector an airstream uses (I assume brakes), but the rover 7 pin does not include brakes which is why you have the 7 to 4 flat converter. The stock rover wiring only gives you lights.
You need a brake controller and need to wire that in as well.
Old January 7th, 2014, 01:07 AM
sro
Sam Odio
2008 LR2
Alright I'm going to go ahead and wire the 7 pin directly to this harness. I have an aftermarket brake controller so I'll go ahead and wire that in as well.
Old January 7th, 2014, 01:50 AM
Not going to work. Land rovers have separate stop and taillights which is why you have the converter to four flat. What year is your airstream? What are the seven wires you need? Reverse, left, right, taillights, ground, brake control?, auxiliary?
Old January 7th, 2014, 04:57 AM
trailer guy's Avatar
trailer guy
Ben Jones
Defender 200tdi 110 Hard Top
They look like UK 7 pin trailer colours.
Over here they are:
Pin - Colour - Function
1. Yellow - n/s indicator
2. Blue - fog
3. White - earth
4. Green - o/s indicator
5. Brown - o/s tail light
6. Red - brakes
7. Black - n/s tail light & number plate
Not sure if that's any assistance? The thing to do is put a multimeter on each of the pins / wires as you activate them see if you get a feed.
i.e. put a multimeter on to the red wire on the harness (before the converter plug/socket), get someone to stand on your brake peddle and see if you get a 12v feed.
NB. Don't forget that our n/s and yours differ! lol
Best of luck
Old January 7th, 2014, 08:03 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I haven't wired my D90 for towing with brakes, but have on both of the Disco's. Here's how I did it. Obviously some differences, but it should point you in the right direction.
http://landroverforums.com/forum/dis...29/#post179231
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 7th, 2014, 10:06 AM
sro
Sam Odio
2008 LR2
Okay, this is the pin wiring diagram for the airstream:
It looks like I need to connect:
- Black - 12V
- Brown, right turn signal
- Blue, aftermarket brake controller
- Red, left turn
- White, listed as 12V but I think that's a typo (probably ground)
- Green, clearance lights
It seems like this should work without a 4 pin adapter or anything other than the 7 pin coupler. I just need to wire the turn signals and running lights directly from the harness in the photo (after testing with a voltmeter of course).
The ground goes to the chassis and 12V from the battery. My plan is to put a 40A fuse on the 12v lead (http://www.etrailer.com/question-44650.html).
Am I missing anything?
Old January 7th, 2014, 10:34 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I'm guessing your trailer has combined brake and turn signal lights. As evilfij said, since the Defender has separate brake and turn signal lights, you need to keep the four pjn connector in your system. You can then buy a 7 pin converter. I've set mine up that way.
For fuse size, check with your brake controller. I use a ProdigyRF and it specified more than 20 amps, so I went with 30 amps.
Old January 7th, 2014, 03:02 PM
sro
Sam Odio
2008 LR2
I see, so the right turn and left turn in the wiring diagram also serve as the brake lights. Makes sense now.
Old January 8th, 2014, 11:30 AM
Antichrist's Avatar
Antichrist
Tom Rowe
You want a self resetting circuit breaker for the brakes, not a fuse. If you have a fault you want at least intermittent brakes until you can pull over and sort it out.
CA (and most states) if your trailer has brakes you're required to have a break-a-way controller on the trailer. Plus it's polite to other users of the road. That battery would be powered by the aux always hot 12v wire, probably the purple one in your photo.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 8th, 2014, 12:00 PM
Those extra green wire is a constant 12 feed to support the battery in the "caravan" (aka RV)
Old January 8th, 2014, 12:50 PM
sro
Sam Odio
2008 LR2
Good to know. I'll get a self-resetting fuse. Already have a break away on the trailer.
Old January 8th, 2014, 02:21 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
One correction, from someone who's already made every possible towing mistake over the years: the breakaway switch should be powered either by the trailer battery or its own battery (if the trailer has no battery), not by the hot wire from the tow vehicle. If the trailer "breaks away," you'd need a really, really long purple wire to operate the breakaway switch!
Bob Vogler
Recovering Economist
Old January 8th, 2014, 06:54 PM
Antichrist's Avatar
Antichrist
Tom Rowe
All breakaway kits come with a small AGM battery (that lives on the trailer) and switch to activate it. The constant 12v from the tow vehicle is to keep the battery charged.
Also, always connect the break-a-way switch before connecting the trailer plug to the tow vehicle. Some controllers can be damaged if you engage the trailer brakes (while hooking up the wire to activate the break-a-way switch) while the trailer wiring is plugged in to the tow vehicle.
Not all are like that, my Tekonsha isn't, but it's a good habit to be in.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 11th, 2014, 09:08 AM
sro
Sam Odio
2008 LR2
Okay, so I ordered a 5 to 4 wire converter for the trailer lights / brakes.
I also ordered 25 ft' of #4 cable for the charging circuit (both Black - 12v and White - ground). Quick question before I hook all this up: how can I make sure the #4 charging cable doesn't trip the 40A fuse when the trailer batteries are being charged by my 120 amp alternator?
Old January 11th, 2014, 11:08 AM
sro
Sam Odio
2008 LR2
Okay, just purchased a bambi 16! Very excited. I plan on using it for extensive boondocking.
Based on this forum, I'm about to install the following:
  • 5 to 4 wire trailer brake light controller
  • 40A charging cable (#4AWG) from TV to airstream with 50A SMH connector
  • 7 pin trailer connector
  • Running 4AWG cable for solar (which isn't yet installed).
  • Installing two 6V batteries (eventually upgrading to 4)
Here's the circuit diagram: https://www.dropbox.com/s/fht48aknqh...g-charging.png
Can anyone see any huge mistakes? Open questions:
  • I'm currently running two connectors to the airstream: a high-gauge cable (pos and ground) and the regular 7 pin connector. Should I scrap the high-amp SMH connector?
  • For faster recharging the alternator battery sense is running off the second 12V battery that's on the vehicle (this will often stay connected to the airstream and drain with the airstream). Bad idea?
  • Second battery will be connected to starter battery when ignition is on so I figure even if the starter battery is low (due to no battery sense) the second battery should be able to start the vehicle.
  • Running lots of 4AWG cable (do I need it all?)
Old January 12th, 2014, 12:17 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I can't speak for much of it off the top of my head (see what happens when you don't use an EE degree for 25 years?), but the 4AWG wire is a waste in most of your connections. The solar connector is only 68 W, or about 5 A @ 12 V - unless you have a run of 500 feet, that's complete overkill. The others are similar. Here's an automotive wire calculator:
http://www.gtsparkplugs.com/WireSizeCalc.html
Save a bit of cash -and- it's a lot easier to run smaller wire.
Old January 14th, 2014, 01:18 AM
sro
Sam Odio
2008 LR2
Thanks. That's helpful.
wiring
Trailer wiring????? JEEPETR Defender Technical Discussions 3 July 13th, 2008 12:42 PM
wiring a trailer hook up jstrong98 Defender Technical Discussions 9 September 27th, 2006 09:51 AM
D90 trailer wiring JEEPETR Misc. Chit-Chat 1 August 3rd, 2005 11:00 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
If you don't have trailer wiring this is the ticket... wicks Misc. Chit-Chat 5 June 2nd, 2004 11:05 PM
