Trailer wiring - Defender Source
Old May 13th, 2016, 11:52 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
Trailer wiring
My 94 doesn't have any trailer wiring. So I ordered a Hella Euro 7-way socket so I can add it like factory. But I'm confused on how to wire it. Land Rover's electrical diagrams show it to be wired like this on both the 93 110 and 97 90:
1: Tail light RH, red/orange
2: Stop lamp, green/purple
3: Direction indicator RH, green/white
4: Direction indicator LH, green/red
5: Ground, black
6: Nothing
7: Tail lamp LH, red/black
But it doesn't match the diagram for the Euro 7 plug posted by etrailer or the one in Hella's catalog.
etrailer diagram:
Hella diagram (matches etrailer diagram):
Old May 14th, 2016, 01:01 AM
Chip's Avatar
Chip
Andrew
Yeah, but I'm not trying to compare the images. I'm comparing the Defender wiring to the 7 way Euro socket. I think I figured it out though. I think the Defender wiring diagrams are for the connector that the adapter with the converter Atlantic Britsh sells plugs into, not the wiring for the trailer socket on the back of the truck, which is what those two images are. I thought that connector and the trailer socket were the same thing until I realized AB's adapter will not plug into the Euro socket. The 94 doesn't have that connector for AB's adapter, so I'll just wire it myself for a flat 4 with a converter.
------ Follow up post added May 13th, 2016 11:06 PM ------
I just found this thread that is helping me figure this out.
http://www.defendersource.com/forum/...ion-27346.html
Old May 14th, 2016, 01:37 AM
Chip's Avatar
Chip
Andrew
Oh, look what I found. So the factory trailer wiring can easily be added to a truck that doesn't have it and you can make your own wiring adapter like Atlantic British sells. It's a Lucas Rists 7 way E Series connector.
Lucas Rists 7 Way E Series Circular Sealed Electrical Wiring Connector - Genuine | eBay
Old May 14th, 2016, 03:47 AM
Check this out:
http://www.britishcaravannersclub.co...ion/wiring.php
Old May 14th, 2016, 01:52 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by Chip View Post
Oh, look what I found. So the factory trailer wiring can easily be added to a truck that doesn't have it and you can make your own wiring adapter like Atlantic British sells. It's a Lucas Rists 7 way E Series connector. Lucas Rists 7 Way E Series Circular Sealed Electrical Wiring Connector - Genuine | eBay
Thanks for sharing the name of that plug! Being looking to scavenge one for some time now!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old May 14th, 2016, 02:05 PM
Chip's Avatar
Chip
Andrew
Thanks for the link Chris. I'm not installing the Euro socket now though. I just got that confused with the Lucas 7 pin connector in LR's diagrams.
Yeah totally. I was just about ready to run down to a local wrecking yard to see if I could find one. So I've been looking at converters on Amazon. This one looks like it might fit the bill. CURT model 55130. Now we can make adapters just like AB's for half the price.
http://amzn.com/B000K2LAPM
Old May 14th, 2016, 02:20 PM
I use the euro 7 pin sockets with the connector above or bullet connectors depending on the truck's main harness.
I like these for the actual socket as they are metal instead of the black plastic.
Durite Socket Caravan 7 PIN Metal 12N BX5 0 692 19 | eBay
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old May 14th, 2016, 02:33 PM
93' NAS 110- #234
where do you all install these on NAS bumpers that don't have the recess?
Mark Kellgren
KM4BOR
Old May 14th, 2016, 05:15 PM
Naplm00
Matthew
They make a hanging bracket of under the rear cross
Old August 1st, 2016, 08:28 AM
steveglloyd
Steve George Lloyd
Defender 90 TD5 2001
Hi There,
I am tagging on to this thread as there seems to be a wealth of knowledge and I have hit a brick wall. I am essentially creating a fly lead to get me from a NATO 12 pin socket on the back of my landy to a standard 7 pin 12n socket so I can attach an Erde 142 trailer.
I have so far bought a 12 pin NATO cable with the required 12 pin socket at one end and I am now in the process of trying to wire in a 12N socket on the other end. The problem I have is that nothing seems to match up, I have had a look in the socket end that I am plugging into the landy and worked out the following...
A=Black
B=Blue
C=Pink
D=White
E=Green
F=Red
H=Unused no cable
J=Brown
K=Unused no cable
L=Unused no cable
M=Yellow - LH Indicator (Got this working)
N=Grey
Having looked at many group forums nothing is matching up let alone a standard 12N wiring Diagram.
Any advice or anything to point me in the right direction would be greatly appreciated.
Cheers
Steve
Old August 1st, 2016, 11:23 AM
If you can't find diagrams online, it can be mapped out in under hour with a test light. -Jeff
Probably the quickest method!!!
Similar thread! http://www.steelsoldiers.com/showthr...-plug-adapters
Old August 4th, 2016, 09:25 AM
steveglloyd
Steve George Lloyd
Thumbs up
Thanks to Jeff for the test light advice certainly helped
A=Black - Not working
B=Blue - Apprently LH Stop but not working
C=Pink - Not working
D=White - Earth - Working
E=Green - Rear Lights - Working
F=Red - Not working
H=Unused no cable
J=Brown - Apparently RH Stop but not working
K=Unused no cable
L=Unused no cable
M=Yellow - LH Indicator - Working
N=Grey - RH Indicator - Working
Problem I now have is that on the 12n 7 pin connector...
The Brakes have a single connector yet I have potentially 2 cables
The Rear lights 2 connectors on the 12n yet 1 cable on NATO
Making progress though
wiring
FOR SALE: ATV Trailer - Folding Trailer Rugbier The Flea Market 4 July 30th, 2015 08:43 PM
m116a3 tool trailer. would make great camping trailer greenmountainrover The Flea Market 6 May 21st, 2015 11:39 AM
1974 Rapier Missile Supply Trailer :: 1974 Sankey Rapier Missile Supply Trailer FV241 kraison Defender & Series Truck Registry 1 September 4th, 2014 01:45 PM
"That's Not a Trailer. Now THIS is a Trailer!" Wolf Fabrication Misc. Chit-Chat 14 February 7th, 2014 11:33 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 11:03 AM
