Trailer wiring - Defender Source
Old March 8th, 2013, 10:49 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Trailer wiring
Did a search through the old treads but nothing that matches my situation.
I have these "spare" wires in the rear on the passenger side behind where the speaker would go. I'm assuming they are for a trailer? The truck has a trailer hitch that had been used, but no electrical connection. The purple wire is always hot, even with the ignition off. The red/black comes on with the lights, but the red/green and brown/green don't seem to do anything? I know there is a light on the dash for when a trailer is plugged in but don't know how it senses it?
Would appreciate any thoughts. Thanks.
Old March 8th, 2013, 09:21 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Check to see if you have a large plug with a rubber cover on it at the right rear behind the tire along the frame. Not sure about the NAS but if you have it that is for your trailer connector. The extra connectors you mention are in that area for additional stuff but might also be for the trailer?
Land Rover 110
Old March 9th, 2013, 08:31 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
There are no other plugs anywhere. I know it has pulled trailers at some point in the past. Either the wiring was removed by the PO or they just pulled trailers without lights?
Old March 10th, 2013, 09:08 AM
Capt Milks's Avatar
Capt Milks
Since you do not have the trailer plug you can use those wires at the right rear to hook up the trailer. I am not sure but think the extra resistance of the trailer lights will trigger the trailer light in the dash? If you do not have all of the wires for the trailer on the right side you may have to get the LH turn from the other side. You will need to get the converter so that you can go from the Defenders Red stop-Yellow turn to the trailers all red stop and turn.
Land Rover 110
Old March 10th, 2013, 05:55 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Thanks for the info. What is the convert of which you speak. Something electronic?
Old March 10th, 2013, 06:03 PM
The PO definitely wired it his way.
Old March 11th, 2013, 09:24 AM
michael67's Avatar
michael67
Michael White
110 Tdi
Defenders have separate brake and turn signal lights. The trailer runs the brake and turn signal on the same light. There's a converter sold at most auto parts store that will convert that for you. Less than $30 at O'Reilly's if I recall, including a four pin trailer connector.
Old March 11th, 2013, 10:00 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Awesome. Learn something new every day. Thanks!
Old March 11th, 2013, 01:58 PM
2411D90's Avatar
2411D90
Bob Vogler
1995 D90 Fastback ST (Beluga Black)
I've wired a number of vehicles for towing, including my D90, and I recommend that you spend the extra few bucks for a "powered" or "isolated" converter, which includes a DC line to the car battery and is essentially a relay that draws the power to the lights on the towed vehicle directly from your battery. The cheaper non-isolated converters run the power to the towed vehicle in series through the vehicle's electrical system (car lights, fuse box, etc.), so in effect you are running two sets of tail/stop/turn lights through one system. This may overload the system and is why you sometimes see a tow car's lights dim whenever the turn signals or brakes are activated.
Here's an example of an isolated converter from etrailer, which I've used a lot over the years and am glad to give them a plug:
http://www.etrailer.com/Custom-Fit-V.../56146KIT.html
Another tip is to make sure you securely ground the system, as most electrical problems while towing are due to a faulty ground.
Bob Vogler
Recovering Economist
wiring
Trailer wiring????? JEEPETR Defender Technical Discussions 3 July 13th, 2008 12:42 PM
wiring a trailer hook up jstrong98 Defender Technical Discussions 9 September 27th, 2006 09:51 AM
D90 trailer wiring JEEPETR Misc. Chit-Chat 1 August 3rd, 2005 11:00 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
If you don't have trailer wiring this is the ticket... wicks Misc. Chit-Chat 5 June 2nd, 2004 11:05 PM
