Trailer Light Connector - Defender Source
Old November 16th, 2003, 02:31 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
I've looked at the FAQs and the old BB. I'm trying to find the connector to plug into for trailer lights. I've read that it's supposed to be behind the right tail light. Well, I've looked inside the light housing, inside the wheel well, and behind the speaker housing on both sides. I'm wondering if I'm looking in the wrong place, or if a PO clipped it out during a wiring mod.
Is this what I should be looking for?
Old November 16th, 2003, 03:43 PM
That looks correct, if you look inside the rear OS wheel well right above the rear crossmembe it should be hanging there. The wires run up inside behind the speaker.
Old November 17th, 2003, 03:21 PM
loykd's Avatar
loykd
Ken Loy
I "think" i'm seeing this split in the wire harness, but no connector. One set of wires run up to the right speaker and the others run to the left speaker, behind the fuel tank.
Ugh. Looks like I'm cutting and splicing to install an aftermarket harness and converter. Can't see spending the $80 for the geniune LR part.
Old November 17th, 2003, 04:31 PM
They sell aftermarket harnesses at Wal-Mart cheap. Just don't forget ground like Jimmy did at MAR, you don't want to have to crawl under a muddy rover to fix the lights for your 600 mile trip home.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Trailer harness plug and/or connector type spoolin440 Defender Technical Discussions 14 October 8th, 2006 04:37 AM
3-pin male connector for the NAS/post 1995 Defender brake light Pat Wanted 5 May 29th, 2006 10:23 PM
trailer light and defrost lite won't go out!? chidiesel Defender Technical Discussions 0 February 18th, 2004 03:39 PM
