Trailer harness plug and/or connector type - Defender Source
Old September 25th, 2006, 01:53 PM
spoolin440
Chris Johnson
I'm clear on how to wire up an affordable setup for towing a trailer but... i just can't come to terms with cutting the factory connector. I know that the "other" side of the factory connecter has to be out there somewhere so that I can build my own factory setup... or at the very least does anyone know the connector type that will slide into the factory piece as individual wires?
I'd buy the Atlantic British unit but all I pull is a 7 pin trailer so don't want to use an adapter everytime... but the have the factory plug!!!!
Thanks in advance!!
Old September 25th, 2006, 03:01 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Good timing, I'm up against the exact same problem right now! I also want to preserve the factory plug, but need a 7-pin for my trailer.
Old September 25th, 2006, 03:38 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Buy the AB kit and just cut off the four way bit and wire the wires into your correct female trailer seven way that you bolt to your truck.
Eric
Old September 25th, 2006, 04:28 PM
spoolin440
Chris Johnson
Yah I think i may end up doing that if I can't find another way.
Old September 25th, 2006, 07:31 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Even though it's $70 at AB, still cheaper than the one RN sells! Looks like the way I'm going.
Old September 25th, 2006, 08:41 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
Try getting a Disco II trailer harness off a junk truck - that's what I did.
Old September 25th, 2006, 08:58 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I pinned out my connector and then used some cheap bullet connectors that slid over the connectors in the plug. I was sure to use a good set of crimpers and then I just siliconed the crap out of it. That way, if someone in the future wanted to put in a factory connector they could, although it will suck to have to dig out all that silicone. I did have to slightly crimp the bullet connectors so that they would fit tightly.
Old September 25th, 2006, 09:29 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I'm a little confused. You guys are talking about making the Defender compatible with a 7 pin connector on a trailer? So you are pulling a trailer with lights and brakes obviously? What are you pulling with a Defender that needs brakes?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old September 26th, 2006, 12:12 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
David-
I'm getting a Horizon model Adventure Trailer http://adventuretrailers.com/ w/ 10" trailer brakes.
Old September 26th, 2006, 12:15 PM
btate
Bryan Tate
d90
If I understand what you are saying, you have the seven pin on your car, but not on your trailer.
What I did was wire a LR connector to a 4 flat connector (or the connector of your choice)
Like an extension cord with the correct connectors.
I have one of the LR connectors (new in box) for that purpose......email me
Old September 26th, 2006, 02:56 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
That's my solution as well - I have the seven pin socket on the truck and a short 18" connector that has the seven pin plug on one end and the flat four connector for my utility trailer on the other end.
Old September 26th, 2006, 03:01 PM
btate
Bryan Tate
d90
In fact, I think I have 2 plugs....one is wired up, the other is new without wires.
You will need to sit down with a circuit tester and figure out what controls what if you are wiring it from scratch......unless you cheat and look at a wiring diagram
Old September 26th, 2006, 05:44 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
Ahh, the ever-frustrating vagaries of Land Rover trailer wiring! Early on, I foolishly cut off the stock rubber socket, in order to hardwire a receptacle for the NATO 12-pin cable from a Sankey trailer. But now I'm towing a U.S.-built trailer, with the seven-pin electrics. So I bought the big-bucks Land Rover kit, and spliced it in to where the rubber plug had been. And then realized that although it terminates in a seven-pin socket, it's the European N-type connector, with round conductors, rather than the flat-pin U.S. style. So I tracked down a male N connector, and wired up an adaptor from that to my U.S. trailer harness.
The solutions you guys are proposing sound much less Byzantine....
Old October 7th, 2006, 10:16 PM
spoolin440
Chris Johnson
ok... I secured a genuine setup but it has the round pins you speak of. When looking at the UK wiring diag. of the EU plug it looks like they account for seperate tails. To save going at it with a test light, does anyone have the color codes for the OEM harness? The unit I have has the block box for converting and the following wires:
Blue
Yellow
White
Brown
Green
Red
Black
Old October 8th, 2006, 04:37 AM
Trevor Tarr
Trevor Tarr
Chris, look here: http://www.electronics2000.co.uk/dat...%20Assignments
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
EFI harness plug rover4x4 Defender Technical Discussions 4 December 6th, 2009 08:04 AM
need Discovery II side repeater Harness Plug FlaD90 Defender Technical Discussions 2 September 16th, 2009 01:12 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
