TPS wiring question - Defender Source
Old June 29th, 2016, 10:39 AM
jrp
John Pisciotta
1995 Defender 90
TPS wiring question
Hello- My first post ever. Like others, I'm having trouble finding a good Throttle position sensor for my NAS 1995 defender 90 with square plug- fault code 17 came up and truck is not running properly. I removed TPS, cleaned it and the contacts than reinstalled- truck runs worse. Does anyone know if wires can be cut from new round plug unit and than wired to the original square plug- and if so, what color wires match up ? THANKS
Old June 29th, 2016, 10:45 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I've tried to do this without success. I found a used TPS with the flat plug through one of the used parts guys on here or discoweb.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 29th, 2016, 03:15 PM
jrp
John Pisciotta
1995 Defender 90
Thanks Brian. Ill look to find a used one.
Old June 29th, 2016, 03:18 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
You would think it would be a simple process since its just the plug. Im guessing they are pretty sensitive so any change in the wiring would negatively effect the ohms.
1995 Defender ST
1996 Discovery SE7
wiring
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Hesitation 88 RRC, Bad TPS? scoot_mcgrute Defender Technical Discussions 2 July 30th, 2009 11:47 PM
Good deal on TPS sensors on E-bay right now.... Hans Misc. Chit-Chat 0 February 13th, 2009 06:55 PM
91 RRClassic intermittent stall-TPS issue? Ren Ching Defender Technical Discussions 6 December 29th, 2008 12:20 PM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
