TPS and Rovergauge - Defender Source
Old April 11th, 2013, 05:30 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
TPS and Rovergauge
I'm assuming my TPS is bad? Do they fail wide open? It seems to run OK, a little rich maybe, but pulls well and idles fine.
Old April 11th, 2013, 06:44 PM
What does it do when you move the throttle? Does it change?
Old April 11th, 2013, 06:48 PM
Seems bad. Replace.
Old April 11th, 2013, 07:28 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
No, just stays on 99% regardless of throttle position.
Weird thing is the ECU isn't throwing any codes
------ Follow up post added April 11th, 2013 07:30 PM ------
Originally Posted by evilfij View Post
Seems bad. Replace.
Do I have to go genuine or is there a GM equivalent?
Old April 11th, 2013, 07:31 PM
I never found a non LR replacement. Charles saved me with a used one as no new ones were available when I looked for one.
Old April 11th, 2013, 07:48 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
This came up on Amazon $209... ouch!
http://tinyurl.com/bs6unmn
Old April 11th, 2013, 08:01 PM
Double check by measuring the resistance across the pins. There is an electrical diagnostic manual kicking around that gives the resistance range.
I'd also check that it's actually connected properly.
Old April 12th, 2013, 03:25 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I took the TPS off and ohm'd it, definitely bad, strange that it didn't throw an ECU code though. Found a used one on eBay. This explains why the plugs had been looking a little sooty, the ECU was probably adding more fuel because it thought the throttle was wide open.
Thanks to all for the help.
Old April 12th, 2013, 03:42 PM
Jason, didn't mine do this when we hooked yours up to my truck last year? I thought it did the same with yours too, no?
Old April 23rd, 2013, 03:28 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
When using Rovergauge, my TPS goes from (corrected) 0%-74% and 6%-74% when corrected. Does that seem correct that it only goes up to 74%? I have two TPS's and they both do this...
Old April 23rd, 2013, 04:42 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
When my TPS was broken, it was pegged at 98% all the time. The new one goes from 0% to 96%, absolute or corrected doesn't seem to matter. Try take yours off and rotate it by hand see what range you get
rovergauge
