Toyo Tire fit - Defender Source
Old April 11th, 2015, 03:19 PM
doscazadores
Vic Stull
none
Toyo Tire fit
Have a '95 D90. Have used a Toyo MT on my truck for years and had very good experience with them.
There's a Toyo MT 255/85R16 that is 33.5 dia. and 10.2 wide inflated. Minimum wheel width is 6.5.
Will they fit under my stock truck?
As always, thanks for input and insight. Vic
Old April 11th, 2015, 03:32 PM
Sure.
Old April 11th, 2015, 04:07 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
They will fit. They will rub the tub when you have lots of weight going over speed bumps or hard corning where your truck leans. Without lots of excess weight you will be fine. Probably end up lifting your truck though.
Old April 11th, 2015, 04:21 PM
No they won't. A 255 will clear fine on a 90 under all conditions.
Old April 11th, 2015, 04:36 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
I just put bfg 255/85R16 on mine (on mil wolf rims) and they rub the radius arms at full lock, had to adjust the turn stops. Also jacked up corners to check clearances to fender flares and didn't see any issues.
Old April 11th, 2015, 06:09 PM
85Red110's Avatar
85Red110
Kent
1985 110 3-door
255/85 Toyo MTs on my 85 110. I have a 2" TF kit on though. No rubbing. These are on 16x7 steel modular wheels.
1985 Land Rover 110 3-door ST
Old April 11th, 2015, 08:55 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
This and the bump stop line should be stickies.
------ Follow up post added April 11th, 2015 08:57 PM ------
Originally Posted by doscazadores View Post
Have a '95 D90. Have used a Toyo MT on my truck for years and had very good experience with them. There's a Toyo MT 255/85R16 that is 33.5 dia. and 10.2 wide inflated. Minimum wheel width is 6.5. Will they fit under my stock truck? As always, thanks for input and insight. Vic
If you get them can you take measurement? Did you get those figures from Toyo's site? Sounds like the Toyo's are a bit bigger than the BFG's which is a good thing.
Old April 11th, 2015, 09:29 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
OK. I guess my 90 in the UK wasn't a 90. if weighed down significantly they will. Wasn't an issue unless the back of the truck was full of lots n of weight.
Old April 11th, 2015, 09:40 PM
Something goofy with your truck or you had weird rims. Lots of people have 255s and they are tested to full articulation on the bumps stops. Extra weight in the truck should not bring any tires close to touching. Fouling happens under maximum articulation.
Old April 12th, 2015, 07:53 PM
doscazadores
Vic Stull
none
Thanks for the replies. Helps a lot. A follow-up question that I should have asked before.
Would that tire work on a 6.5" wheel? Or need to step up to 7"? I've wanted to get away from the stock wheel for some time and thought I'd do it now to get steel wheels.
Old April 12th, 2015, 08:26 PM
6.5" is a good size, but 7" is fine as well. What wheels do you have now? Offset of the wheels is an important consideration in which to use.
Old April 12th, 2015, 08:46 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
They were KM2s mounted on wolf rims on a 1984 90. Springs weren't saggy. I don't have any answers besides that. Maybe it wasn't the tub but some rivets or bolts hanging down thru the tub? It did have side facing bench seats in the back for a while before I replaced them I honestly don't remember what the mounting bolts were like for the benches that were in there when I bought it.
Old April 12th, 2015, 08:56 PM
doscazadores
Vic Stull
none
Running on the stock wheels now. But have always preferred steel on just about everything I drive so looking to go with steel when I get new tires, and I'm leaning toward the Toyos based on how well they did for me on the pickup.
Thanks again.
Old April 12th, 2015, 09:24 PM
I would suggest Wolf wheels with a 255. 6.5" and a nice offset for that width of tire.
tire
1 Toyo proxes st 2 275/40R20 tire 4 sale Grover For Sale - Parts 0 June 3rd, 2014 10:25 PM
4 Toyo Open Country A/T tires cellulararrest For Sale - Parts 0 May 18th, 2007 12:01 PM
Toyo Open Country M/T cellulararrest Defender Technical Discussions 9 February 23rd, 2007 10:57 AM
Toyo MTs? howellm70 Defender Technical Discussions 1 February 25th, 2006 06:27 PM
hard spare tire cover - will this fit a D90 rim? jaherring Defender Technical Discussions 2 October 11th, 2004 01:16 PM
