Towing Options? - Defender Source
Old July 5th, 2011, 10:38 PM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Smile Towing Options?
So I would like to take my D90 on vacation w/ me to Florida. I would prefer to tow it either on a car trailer or something else. I heard somewhere that you can't tow four wheel drive vehicles with a tow bar or with two wheels being on the road as it can damage the transmission or transfer case, is this true? Are there options for towing a D90 or will I just have to rent a car hauler/trailer?
Old July 5th, 2011, 10:50 PM
grnrvrs's Avatar
grnrvrs
Paul
88
If you want to tow the 90 with a bar, you could disconnect both drive shafts. However, IMO a trailer would be much nicer/easier.
Old July 5th, 2011, 10:58 PM
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
flat tow
I flat tow our Defender all the, time set the main gearbox and transfer box in neutral, differential lock in the unlocked position.
Unlock the steering by turning ignition key to the first position and disengage the parking brake.
Away you go.
Old May 17th, 2012, 03:10 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
So after doing some D-90.com research it seems that you can safely tow a D90 with a bar wherein the front tires are off the road when you disconnect the rear driveshaft from the rear diff/transfer case. Can someone confirm this for me? I'm going to Florida for two weeks on Sunday and cannot imagine being without my D90 for that long, especially in that environment. If this set up works I would be towing behind an 07 Yukon XL, anybody know of any issues in that regard? Also any recommendations as to where to buy a tow bar appropriate for towing a D90 in this sort of situation would be appreciated. Also fyi, I live in Dallas and hope to tow my D90 about 800 miles to Florida.
Old May 17th, 2012, 03:23 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Check out U-haul for towing trailer ideas.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old May 17th, 2012, 06:17 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Any particular reason not to just drive the D90 to FL?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 17th, 2012, 07:24 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
A flat tow is possibly the easiest but will work both axles, not that that is a problem. A tow dolly that raises the front will put some weight on the tow vehicle and again you will wok an axle gearing. In both of these cases you are using the tow vehicles brakes to stop everything. Again not a problem but it will work the brakes on the tow vehicle and extend your braking distances. The best option is to have a trailer with brakes. No wear and tear on the Defender, easier on the tow vehicle and better braking distances. If you have time you might be able to find a used tow dolly that would be cheaper than renting. A car hauler can cost, new, any where from $2,500.00 on up. But always watch the trailer rating. The Defenders are not light.
Land Rover 110
Old May 17th, 2012, 11:37 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
Mainly because I'm getting pretty close to 90,000 on the odometer and I'm in denial about my truck ever having more than that amount of miles on it. Also 800 miles in a ST D90 would not be the most comfortable/quiet drive, still though part of me thinks it would be fun. And I don't want to have a break down or have something go wrong. Oh and it would take about 4.5 tanks of gas. But I'll look into towing options so thanks, maybe I'll have to wait till another time I go.
Old May 17th, 2012, 02:42 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
flat tow it, no problems..
Old May 17th, 2012, 04:22 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
it amazes me the length we sometimes go for these silly trucks
have a great trip
Old May 17th, 2012, 04:55 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I haven't driven my D90 that far, but my Lightweight a lot farther, both with and without the top. I've never thought of it as an ordeal. But I guess it's all relative.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 17th, 2012, 05:03 PM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
If you decide to flat tow without disconnecting the drive shafts will you still accrue the miles on the odometer provided the TC is in neutral?
Old May 17th, 2012, 07:26 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Just leave the top and the windows at hone and bring extra ear plugs!
Will be the best drive you ever had!
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old May 18th, 2012, 12:42 AM
I assure you it can't be louder than my 90 with Mud Rover tires, surrey top, I believe a 1.6 gear box, and some crazy diff gearing which runs me at 3500rpms @ 75mph and just shy of 4000 @ 80. It's crazy loud. And I just drove 425 miles to NY. Of course, I recommend purchasing the Sony noise canceling earbuds...they worked great!
Old May 18th, 2012, 07:08 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Just rent a uhaul trailer for 100 bucks each way. They have surge brakes and your truck can tow 3 defenders.
Old May 18th, 2012, 07:59 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
The ST was meant to be driven! You're going to miss out!!! You could just get ear plugs. I drove my ST(now sold) from LAX to RIC in February 2011 and took a side trip through Ohio...man was it cold!! but would do it all again. You have a great 800 mile trip where youre going. Good Luck!!
wing
Roll cage options mod4b Misc. Chit-Chat 2 March 23rd, 2005 01:17 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Aftermarket distributor options. draaronr Defender Technical Discussions 1 September 29th, 2004 07:30 PM
Ski rack options? SFD90 Defender Technical Discussions 5 November 12th, 2003 07:57 PM
Transmission Replacement Options??? JRowe Defender Technical Discussions 17 October 14th, 2003 10:46 PM
