Towing eyes... - Defender Source
Old September 11th, 2012, 12:42 AM
dlane's Avatar
dlane
David Lane
1997 AA Yellow #1147
Towing eyes...
So, I am starting to tow my Defender a lot now since I bought a trailer for it. The eyes are getting pretty bent with the stress. Should I be worried about them failing. Should I figure out a different way to strap it down? If so, what?
Thanks!
dave
Old September 11th, 2012, 01:10 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
have any photos of whats going on?
Old September 11th, 2012, 02:43 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
You could just go after the frame or axles:
http://www.truckntow.com/c-147041-towing-hooks.aspx
http://www.truckntow.com/c-147030-ax...ck-straps.aspx
Or a chain around the frame always works.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old September 11th, 2012, 05:56 AM
Toeing companies are moving away from frame and axle straps and going to tire straps.
Old September 11th, 2012, 06:41 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Use axle straps, and straps front and rear on the frame to keep the truck from bouncing.
Semper Fi!
Old September 11th, 2012, 08:42 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
x 3 or 4 by now...retain it by the axles, not the frame.
We've got short axle straps that attach to the ratcheting straps to the trailer tie down points.
http://www.summitracing.com/parts/SUM-G7965/
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_99986895-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-99986895&ci_src=17588969&ci_sku=99986895&ci_gpa=pl a&ci_kw={keyword}
But if you go to your local Big Truck place, they'll have all the variety you'll likely want to look at.
wing
towing with a D-90 gofins Defender Technical Discussions 9 October 20th, 2005 11:53 AM
Towing your D-90 tron Defender Technical Discussions 2 August 17th, 2005 01:40 PM
Towing a D-90 - Do I need a flatbed? arbik Defender Technical Discussions 4 January 27th, 2005 12:33 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
