towing bridle - Defender Source
Old July 22nd, 2008, 09:56 PM
hamiamham
mike
97 D-90
towing bridle
im going to replace my factory tie-downs in the front with jate rings and was wondering if anyone had . suggestions for a towing bridle (strap/rope/chain?) that can be used with this set-up>
Old July 23rd, 2008, 12:01 AM
hamiamham
mike
97 D-90
let me clarify; a bridle to attach to a yank strap or similar for getting out of stuck situations not towing per se
Old November 30th, 2008, 08:03 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Did you ever get an answer on this question. I am wondering as well.
Old December 1st, 2008, 01:58 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Two of these
http://www.amazon.com/BullDog-Tree-S...8157770&sr=1-8
and a screw pin shackle of suitable rating should give you what you want.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 1st, 2008, 02:04 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Just make sure that the length of the bridle 'legs' is at least twice the length of the distance between the two tow hooks. If it is not, there will be an inward component to the pull that will not be well received by the frame rails...
~Scott T.
'95 D-90 ST - AA Yellow
Old December 1st, 2008, 04:27 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Yes, 8' straps might be better, depending on that distance.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
idle, wing
Flat towing dnp Defender Technical Discussions 22 April 13th, 2007 10:42 PM
towing with a D-90 gofins Defender Technical Discussions 9 October 20th, 2005 11:53 AM
Towing your D-90 tron Defender Technical Discussions 2 August 17th, 2005 01:40 PM
Towing a D-90 - Do I need a flatbed? arbik Defender Technical Discussions 4 January 27th, 2005 12:33 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
