Towing 2000 lbs. with D90 - Defender Source
Old June 2nd, 2006, 08:19 AM
d90Monkey
James
1995 D90
I have a 7x14 trailer that when fully loaded is around 1700-2000 lbs. Research has showed me my 95 D90 can handle up to ~7000 lbs. My concern is that when I drop the trailer onto the hitch the back squats pretty low and the front end comes up a bit. Due to the short wheel base I was wondering if there is a concern that the wieght could actually cause the front to lose contact with the road and then lose the ability to steer. Has anyone towed a heavy load that can assure me I am worring over nothing?
Thanks.
Old June 2nd, 2006, 08:34 AM
Andrew Vick
Andrew Vick
95 D90
How far are you going? Short trip, no problem. I wouldn't want to go very far for the reasons you mention.
Old June 2nd, 2006, 08:48 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Tongue weight ...
Hi Andrew,
It depends mostly of the tongue weight of you trailer or how it was loaded. Their is a tougue weight limit for the 90 that I dont have but it is usualy around 250-300 lbs. In respect to that weight their should not be any problems. You can find that info in the owners manual (usualy). So that way you can carry a very heavy load but if you have a trailer that has a tougue weight of 200 pounds it is no problem (why a 4 wheel trailer is better than a 2 wheel one).
Pat.
Old June 2nd, 2006, 05:32 PM
d90Monkey
James
1995 D90
How do you figure out/ find out the tongue weight?
Old June 2nd, 2006, 06:30 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Load the trailer, put a 2x4 under the hitch with one end on a scale of your choice. Read the weight on the scale. Don't let the trailer move while teetering on the 2x4.
This is the poorboy way. A trailer supply business may check the tounge weight for you.
There is more info on towing with a D if you want to search the forum.
Don't even consider trying to tow 6 or 7 thousand pounds with a Defender.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old June 2nd, 2006, 06:56 PM
scoloco's Avatar
scoloco
'94 D90 ST
I tow a tent trailer periodically. Loaded up its around 1800#. No worries except for a. no power on a grade and b. lousy braking. But I dont even know its there much of the time on the flats. The truck weighs in over double the trailer, so not much of a problem there with handling. YMMV.
I recall LandRover rating something at 7000# tow -- but in low range. 5000# in hi. I think this was a disco I, which is essentially the same drivetrain with slightly longer wheelbase.
Old June 2nd, 2006, 07:51 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
What I meant to say is, Personally, I wouldn't even consider trying to tow 6 or 7 thousand pounds with a Defender.
Does anybody know how the people who look out for us determine the towing capacity of a vehicle?
Old June 2nd, 2006, 08:25 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
It has to do with the capacities of the axles, drivetrain, and suspension.
My unimog has a MAX tow rating ov over 30tons but that is with a "self contained" trailer (self supporting, with front and rear wheels, and it's own self sufficient braking system)
You can tow more than you can imagine, in the right conditions.
I got your JEEP thing, now it hurts when I pee!!
Old June 4th, 2006, 04:53 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep, you might even need low ratio to pull away to save the clutch.
Mike Hammond
Old June 5th, 2006, 12:40 PM
eh, 7000lbs is no biggy. East coast of course, would not want to do it over one of the rocky mountain passes.
Get a 4in drop hitch, it will fix your tongue weight issues.
Old June 5th, 2006, 05:07 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
Is there a limit then on how many fat chicks Mike can pick up at the bar?
Old June 8th, 2006, 01:41 PM
mountainviewrover's Avatar
mountainviewrover
MARK LECLAIR
95 Range Rover Classic
7000lbs divided by 300lbs ea.............. just had to put that out there.
2000, 90, d90, wing
WTT - Your d90 for a 2000 E320 Wagon uzj100 For Sale - Vehicles 1 September 19th, 2006 08:46 AM
Trade 2000 D2 for your D90 ChicagoDon For Sale - Vehicles 2 November 1st, 2005 11:11 AM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
2000 BMW 323Ci for sale or trade for d90 Campbell For Sale - Vehicles 0 May 3rd, 2004 08:39 AM
