Touchscreen stereo install without cutting dash? - Page 2 - Defender Source
Old March 6th, 2016, 01:48 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
This one by Brandmotion is pretty close. It has a 7.3" wide LCD that can display one image or two 3.6" images side by side. It's $319.95 from Summit Racing.
http://www.brandmotion.com/rear-visi...fltw-7692.html
Old March 6th, 2016, 06:54 AM
Why not use your IPad/tablet and just add an amp?
Who was making that mounting bar across the top of the dash? Add a suitable ram mount to that and you're good.
Old March 6th, 2016, 07:46 AM
BlackField's Avatar
BlackField
Oscar
D110
I used a really simple amp with a 3.5mm on my old 110. I'm sure there are much better options now, probably bluetooth enabled stand alone amps. But yeah, an iPad mini and an amp will do pretty much anything better than an in dash head unit will.
edit:
http://www.fullcompass.com/prod/2851...FcIXHwodUnAMIw
Old March 6th, 2016, 08:28 AM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
I think the simplicity of the defender dash makes it great. The rear view mirror / backup camera option is perfect if you are constantly hitching up stuff, plus it maintains the dash. I have nav in my 4 runner, but I find that I use the iPhone almost every time. Bluetooth, backup camera, and some radio stations are about all I need. Do any of the rear view mirror options include Bluetooth?
Old March 6th, 2016, 03:18 PM
Chip's Avatar
Chip
Andrew
There are some aftermarket mirrors that have Bluetooth, some even with Nav, but I don't think they're great based on reviews. I ordered a Bluetooth add-on module for my existing head unit (Alpine CDA-117).
The iPhone/iPad mount is a great idea.
Old March 6th, 2016, 07:00 PM
edit:
Pyle Pro PFA330BT 90W Amplifier with Bluetooth | Full Compass
I like your solution better than the one I had in mind.
Kicker 40PXIBT50.2 2-channel amplifier/controller with Bluetooth® — 25 watts RMS x 2 at 2 ohms at Crutchfield.com
Old March 7th, 2016, 11:35 PM
Chip's Avatar
Chip
Andrew
I found the part number for Nissan's full display mirror. It's pretty much exactly the same as the Gentex one in the GMs. It's K6321-3GP00. I'm not sure how to order it from Japan though. It looks like it's an option that costs 60,000 yen on the X-Trail (Rogue), Elgrand, and Serena. Apparently it was suppose to be available in the USA for 2015, but maybe they didn't get gov't certification yet. Looks like Gentex's mirror for GM was approved by the NHTSA just a couple weeks ago (article here.)
Nissan's Rearview Mirror Backup Camera | Nissan USA
Nissan Japan Smart Room Mirror Option
It's on Rakuten Japan here.
Old March 8th, 2016, 12:23 PM
Chip's Avatar
Chip
Andrew
If anyone's interested, jp-carparts.com can order the Nissan full display rear view mirror. It's in stock. It's $519.39 plus $45 shipping and $22.58 PayPal fee, so $586.97.
One thing to consider though is that it's not a back-up camera. Not unless you mounted the camera low and switched it on when you're backing up. So not ideal I suppose if the purpose of having it is to avoid backing up over children and pets. And as the camera is intended to be mounted high, that wouldn't really be possible on a ST Defender. So I think it's best suited for a SW.
" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Old March 8th, 2016, 03:30 PM
Chip's Avatar
Chip
Andrew
You know actually, the camera could be installed under the 3rd brake light on a ST. The display mirror could be pretty useful when the top is on.
Old March 8th, 2016, 05:10 PM
doktorno
Chris deZ.
1995 Defender SW
Have used the Ipod/iphone as a head unit and like the result.
I used this cable to charge the iphone/ipad JamLink CAR - iSimple and it has RCA outs that I plugged into this JLAudio remote level control. CL-RLC - Car Audio - OEM Interface - System Expansion - JL Audio that will run any aftermarket amp.
So if you get in my car and turn on the 1971 Becker Europa the antenna goes up and you get radio/cassette out of the single dash speaker. Or flip a small switch and have 900w running through ten hidden speakers controlled by two small black knobs, one for volume and one for sub.
Old April 22nd, 2016, 02:14 PM
Chip's Avatar
Chip
Andrew
The Gentex full display mirror installed in the new Cadillac CT6 and XT5 is now available to order. It's $675 list. $526.50 at GM Wholesale Parts | Quality OEM Parts. (See post #17 for info and for the camera.)
Old November 1st, 2016, 08:29 PM
Chip's Avatar
Chip
Andrew
The Gentex full display mirror will be available as an aftermarket kit early next year. The SmartBeam automatic high-beam module will also be available as a stand-alone product.
Gentex To Debut New Aftermarket Version Of Its Full Display Mirror(R) At SEMA
Old November 1st, 2016, 09:10 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
What's the best option for a Puma dash? There's more room & the mounting surface is flat, so should be more options?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old November 3rd, 2016, 03:23 PM
yankee
Bala
edit:
How have you mounted your iPad? Do you connect your phone via BT as well to the unit?
Old November 3rd, 2016, 03:38 PM
KGH's Avatar
KGH
Real Name
#1-'13 110SW,#2-'87 127,#3-'12 LR4
Get a Puma double DIN fascia. You move some switches to the side.
Here is a pricey example. Cheaper options out there.
DEFENDER2.NET - View topic - Puma TDCI Double DIN facia panel
KGH - Defender Snob
Old November 3rd, 2016, 08:48 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
I just installed this single din 8 inch touch screen android car stereo from Joying. It works great. Dash left unmodified. Bluetooth, Spotify (downloaded songs), FM, navigation, movies, backup camera. Love it.
Old January 9th, 2017, 11:00 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Kind of liking the look of this. Is the screen angle fixed? Can you remove the screen?
Old January 9th, 2017, 11:03 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Screen angle is fixed but it's a good angle. You can adjust up and down along the Y axis. Screen is removable but I believe there's a wire you have to unplug.
Old January 9th, 2017, 11:28 AM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Any chance you have a model #? Looks like they have quiet a few different single din 8" models.
Old January 9th, 2017, 11:37 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So not something you would necessarily take out when you left the vehicle?
dash, stereo
Xenarc 7" touchscreen sunlight readable Overlander The Flea Market 0 December 6th, 2015 01:31 PM
Install Puma Dashboard on 300 TDI without installing a new Gearbox DininduInduwara Smaller Projects 9 October 5th, 2015 06:48 PM
ARB locker install without air Overlander Defender Technical Discussions 2 February 14th, 2014 10:14 PM
Touchscreen tablet/docking station/RAM mount/keyboard (Onboard Nav setup) Ray_G For Sale - Parts 1 August 15th, 2011 09:51 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
