totally confused..torsion clutch pedal spring - Defender Source
Old December 17th, 2012, 10:18 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I am totally confused... My Torsion Clutch Pedal Spring broke and the replacement is a different size and wont fit. This is for a late 94 or 95 clutch on a R380. The replacement that I have is LR part# EDP7510L (again it is the wrong size).
Here are some pics:
clutch torsion spring Broken Old on left New on Right NAS D90 (1st Pic)
clutch torsion spring Old on Left New on Right NAS D90 1994 (2nd pic)
I also included a couple of generic pics to show you more of what I am talking about (3rd & 4th pic)
Any help would be greatly appreciated. By the way, since 2001 this is my second clutch spring to break... So others may be in similar situation. Again any help/thoughts/suggestions are really appreciated.
Rufus
Name:	clutch torsion spring Broken Old on left New on Right NAS D90 1194.jpg
ID:	62825   Click image for larger version
Name:	clutch torsion spring Old on Left New on Right NAS D90 1994.jpg
ID:	62827   Click image for larger version
Old December 17th, 2012, 10:27 AM
You may have the skinny clutch pedal arm and they provided you with the spring for the fat clutch pedal arm.
Here are the differences.
Mine: 1995
http://www.defendersource.com/forum/...9&postcount=73
vs. Jeffhuf 1994
http://www.defendersource.com/forum/...5&postcount=76
Name:	clutch pedal arm - skinny 1995.jpg
ID:	62829   Click image for larger version
Name:	clutch pedal arm - fat 1994.jpg
Old December 17th, 2012, 10:38 AM
Naplm00
Matthew
Picture on the right looks like a ROW truck
Old December 17th, 2012, 10:48 AM
Rufus's Avatar
Rufus
Rufus
Josh, thanks for the input - I definately have the skinny clutch pedal arm and not the fat. Mine is a late NAS 1994 so I believe it is the same as a NAS 1995.
Matthew, I am sure one of those generic pics is from a ROW, I just used that pic to help illustrate what the clutch spring looks like on the clutch pedal.
Old December 17th, 2012, 10:54 AM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
are you working on that today? hope the heat is working well in the barn.
Old December 18th, 2012, 09:43 AM
Rufus's Avatar
Rufus
Rufus
someone has to have an idea on this one. anyone with an R380 come across this before? I am thinking this spring is the same regardless of NAS or ROW.
Old December 18th, 2012, 04:29 PM
Rufus's Avatar
Rufus
Rufus
THANK YOU George at RDS! I measured my broken spring vs. what he had in stock and he has the right size. What a nice guy.
Old December 18th, 2012, 04:56 PM
But have you figure out what they sent you?
Old December 19th, 2012, 10:04 AM
Rufus's Avatar
Rufus
Rufus
it doesn't seem like anyone knows why there are 2 sizes with the same part #
Old January 14th, 2014, 01:08 PM
Rufus's Avatar
Rufus
Rufus
old post new insight
I was originally totally thrown off by the 2 different spring sizes and when I got the small spring, I thought I got a series part or something.. Anyways, I ended up getting 2 springs (sm size and original size) and have been using the spring that was the original size as the replacement all this time. I had the smaller one kicking around and for kicks installed it. As it turns out, the smaller spring works just fine if not better. It makes the clutch pedal seem a little more stiff which I like.
Anyways, I just thought I would follow up in case anyone else was confused by 2 different spring sizes under the same LR part number.
BTW - since 2001 I have had 2 of these springs break, so it is a good spare part to have kicking around. Also a good idea to get new nylon bushings when replacing the spring
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old January 14th, 2014, 01:18 PM
Yes, the smaller spring works fine. I had this issue on my late 94 and scratched my head for a second and then just fit the smaller end spring george (or RN I forget) sent me.
The early pedals (SII up to late 94 -- as shown in post #2 above) do not have the coiled spring like that, they have the long thin spring which clips to a tab on the bulkhead.
clutch
CLutch Spring Installation rlynch356 Defender Technical Discussions 7 August 15th, 2017 07:28 AM
Clutch spring mlorman Defender Technical Discussions 9 June 16th, 2011 08:54 AM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
