Torque Steer - LSD - Defender Source
Old April 10th, 2009, 09:38 PM
CDeWan
Clay DeWan
5.3L beastie
Torque Steer - LSD
O.k. here goes. Installed a Detroit TrueTrac in the front. I was expected a little bit of torque steer but am getting a more than I expected.
Front end is tight
I am running stock springs (new)
ES9000 shocks
Bilstein Steering damper.
So I wanted to explore the options on how to counter act this:
1. ? Get a more heavy duty dampner
2. Go with a heavy duty spring set up to reduce body roll hence reducing torque steeer
3. Go with a heavy duty bilstein (this is not my favorite choice as I like playing in the sand and have to deal with washboard roads)
4. any other choices suggestions?
Thank you in advance.
Old April 11th, 2009, 02:07 AM
4x4sche
john
73 SIII_ 97 D90_94 Disco
I put TrueTracs front and rear in my 97. I have the stock springs, HD Bilstein shocks and Bilstein steering damper.
I noticed a slight difference in steering, but nothing to complain about.
Are you sure you have a front Truetrac unit and not a rear one?
The parts are the same but they are put together differently. You can convert one to the other. Also the belville preload washer will bed-in after a while reducing the torque effect. You can easily get full torque transfer performance off road by lightly applying the brakes to load a slipping wheel. For this reason you can even replace the spring washer with a plain one. Then the TrueTrac is not even noticable on-road.....BTDT.
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
torque wrench rover4x4 Misc. Chit-Chat 9 December 26th, 2005 02:06 PM
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
Torque for road wheels? Chaucer Misc. Chit-Chat 0 November 13th, 2004 06:26 PM
