Torque spec for balljoint bracket to Salisbury Axle?? - Defender Source
Old May 16th, 2015, 10:02 AM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
So I've read the workshop manual and have asked around but can't seem to find an answer that's clear.
I have a Salisbury rear axle and to the side of the differential casing bolts a bracket which the ball joint for the upper linkage bolts into. This bracket is held on with 4 M12 bolts. I'm trying to determine what the torque rating for these bolts are. The manual says 176Nm for the ball joint but doesn't say anything about those bolts. I assume that's since many models ball joints bolt into a welded on bracket.
I've had people say that they think the bolts take 176Nm as well, but that's over the torque limit for an M12 bolt so I can't see that being correct. HELP!
Attached is a picture of the bolts in question.
Name:	Screen Shot 2015-05-15 at 8.22.58 PM.png
ac, axle, bracket, rack
Torque spec's for thermostat housing bolts Roover Defender Technical Discussions 2 May 17th, 2014 07:58 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
upper link balljoint dust cover JFD Defender Technical Discussions 0 October 5th, 2010 01:16 PM
Torque Spec Grover Defender Technical Discussions 6 June 7th, 2010 08:21 AM
Taper on A-frame balljoint??? ezzzzzzz Defender Technical Discussions 0 July 2nd, 2004 08:50 AM
