Torque Spec - Defender Source
Old June 3rd, 2010, 07:38 PM
Grover's Avatar
Grover
Question Torque Spec
Searched but couldn't find...
What's the torque spec on the rear ball joint castle nut? The 30mm nut that fastens the ball joint to the top of the rear axle...
Sláinte...
Old June 3rd, 2010, 10:56 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
130 lb ft. per RAVE.
Old June 4th, 2010, 07:57 AM
LFORGUE8
Lucas Forgue
2011 Rangie
Damn tight! Ive tried to get a socket in there with my 1/2" torque wrench but i cant see a way to do it.....
59 SII....on the back burner!
11 Rangie
Old June 4th, 2010, 12:39 PM
Grover's Avatar
Grover
Thumbs up
Thanks Kevin. I looked in my RAVE and in my paperback workshop manual, but couldn't find it.
I was able to get a MAC 30mm socket in there, it was tight though. Took everything I had to break it loose.The only problem now is breaking loose the long bolts that attach the ball joint carrier to the A frame arms. Soaked them in penetrating fluid lastnight...hopefully that will do the trick...
Old June 5th, 2010, 10:40 AM
LFORGUE8
Lucas Forgue
2011 Rangie
ive got a snap-on so maybe there a difference........if you cant get those a arm bolts off just cut them flush and try to pound the arms outward then drill.....ask me how i know that!
11 Rangie
Old June 5th, 2010, 10:56 AM
Grover's Avatar
Grover
The long bolts are seazed in the ball joint carrier
I was able to get remove the 2 nuts and remove the passenger side arm, but since the bolts are seazed, I can't get the other arm off. I'll soak it more.
Old June 7th, 2010, 08:21 AM
LFORGUE8
Lucas Forgue
2011 Rangie
I would try to remove what you have left and work on it on a bench.....also the rear bushings on those a-arms could stand a replacment as well im sure!
cut the nut end of the bolt off and try to remove the other arm then you'll have to cut the bolts flush with the "ball joint carrier" then drill....at least that what it sounds like
11 Rangie
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
Bendix of a 94 NAS spec starter B-Kerr Wanted 0 April 13th, 2005 10:37 AM
