Torque Converter re-Install trouble - Defender Source
Old November 5th, 2005, 09:47 PM
Michael
Michael
Discovery 1998
This is for a 98 Disco.
I am not able to get the torque converter as far onto the input shaft, or "home" in the oil pump. I need another half inch. I have been turning the torque converter for what seems forever but not luck..
Any suggestions?
Old November 6th, 2005, 04:33 AM
ashtrans
Dave Ashcroft
get the auto vertical, bellhousing up,
put 2 bolts in the torque converter, spin it and rock it until you get 50mm from the bellhousing face the the torque converter feet,
Dave
Dave Ashcroft
Old November 6th, 2005, 07:31 AM
Michael
Michael
Discovery 1998
Torque converter
Thanks for response. I have visited your site a few times in the past. Thank you for all the technical information that is posted there.
I am trying to avoid removing the transmission. The reason I removed the torque converter was to remove and modify bell housing to accomodate the diesel engine I am fitting.
Is it possibe that I damaged the internals of the torque converter when I removed it? The transmission was horizontal when removing and it slid out pretty easily. I did not drop it on the floor, but I do know that as I pulled it out it did drop a little to find support on the "hollow shaft", and then the input shaft.
Thanks again.
Old November 6th, 2005, 09:18 PM
Michael
Michael
Discovery 1998
Torque converter is in!
Yee-Haw!
Thanks for the help Dave. I pust a little more effort into it and it worked.
Best,
Michael
Torque Converter for TDI300 Disco Auto Eddie 1 Defender Technical Discussions 3 September 27th, 2007 01:52 AM
Forcing Torque Converter Lockup Trevor Tarr Defender Technical Discussions 6 September 10th, 2007 12:35 PM
I'm in trouble w/ the Mrs.. pix of Full Rack install needed paulb Defender Technical Discussions 5 June 6th, 2005 09:40 PM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
» Defender Registry
110
clb1994
CTX
4RF RDS
Add your Defender
