torque - Defender Source
Old May 20th, 2004, 05:24 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
torque
What should the bolts on the transfer case be torqued to? I'm going to open it tomorrow and see what's in it.
Jimmy Buffett
Old May 20th, 2004, 06:43 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Be more specific! I would be glad to help.
Peter
Old May 21st, 2004, 08:04 AM
Tyler you mean the bolts on the bottom cover right?
Old May 21st, 2004, 09:26 AM
flippedrover
Tyler
'94 D-90
yep. The ones that i can take off to look inside.
Jimmy Buffett
Old May 21st, 2004, 09:31 AM
I think they are 25-35 ftlbs
Old May 21st, 2004, 09:35 AM
flippedrover
Tyler
'94 D-90
Ok.
Jimmy Buffett
Old May 21st, 2004, 09:38 AM
that seems a tad high
the spec on the case bolts are fairly low as it is only alum. threads. in any case, tight but not overtight. I use 1/4 drive to prevent stripping the threads.
In any case (pun intended) i would not be concerned about the spec on those bolts. Just tighten them up but not too much. 4 of the 8 have locktite on the threads so they are not going anywhere. Especially after you seal it up with right stuff.
Old May 21st, 2004, 09:39 AM
http://www.spanishtrailrovers.com/Te.../rrm_lt230.pdf
Old May 21st, 2004, 09:44 AM
They have the specs: 16-21ft/lbs
Old May 21st, 2004, 10:30 AM
flippedrover
Tyler
'94 D-90
Ahh. thanks
Jimmy Buffett
Old May 21st, 2004, 10:57 AM
My bad
Old May 21st, 2004, 12:15 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
My 2 cents worth! In my Man it says 25Nm=18.44lbs/ft.
Old May 21st, 2004, 01:03 PM
flippedrover
Tyler
'94 D-90
Interesting.
Jimmy Buffett
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
torque wrench rover4x4 Misc. Chit-Chat 9 December 26th, 2005 02:06 PM
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
Head bolt torque Bowtracer Defender Technical Discussions 1 September 14th, 2005 11:22 AM
Proper waterpump torque? cgalpin Defender Technical Discussions 11 April 17th, 2005 09:45 PM
