Torn trailing arm bushing - Page 4 - Defender Source
Old November 27th, 2012, 11:33 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Originally Posted by mongosd2 View Post
If you look at the picture of the "pin", while it is single shear, there is a misalignment spacer machined into the piece that captures the center of the joint, also machined into the "pin" is a safety washer, even if the joint self destructs, the safety washer will hold the cage of the joint. These joints are not under heavy load in a steering tierod application and have a static load rating of over 28,000 pounds.
Please post up one picture of a failed QA1 hiem used in a tiered application.
They are trail tested, tried and true, made in America joints.
I think this is a discussion of best practice vs. practicality. I think we all agree that a best practice and for the most extreme circumstances, mounting a rod end/heim joint in double sheer is ideal. However, as Frank pointed out, in this particular application (tie rod/drag link), the forces applied should not reach a point that would cause failure. If I were in a KOH style custom buggy running 44's and hydro steering on my Dana60 then I may think differently!
Old November 27th, 2012, 12:31 PM
Yes, I am being an enginerd with my comments and they are in no way to be considered an attack or criticism.
Although I do think that going with a ball joint instead of a spherical joint to ball joint adapter (?) is kind of an expensive way of doing what a ball joint does already.
But I guess if it's to stay with a standard thread-size for the weld-in bung then it's a solution to a problem!
Old November 27th, 2012, 01:12 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Not aken as criticism...but tierods end are more expensive and there's no tube adapter available for the LR tierod end. I could thread a piece of solid tube, but a 4" pice of solid tube is WAYYYYYYYYYY expensive.
I run these on my full hydro steering on my D2..
Old November 27th, 2012, 01:22 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Like the design. What QA1 hiem is being used?
http://www.qa1.net/qa1_motorsports/i.../rod-ends.html
Old November 27th, 2012, 01:42 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I use the XM series...
http://www.qa1.net/qa1_motorsports/i...oly-steel.html
Rear trailing arm instalation jayz Defender Technical Discussions 9 August 31st, 2012 06:33 PM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 09:02 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
