Torn trailing arm bushing - Page 3 - Defender Source
Old November 26th, 2012, 03:13 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
The holes in the frame mount are not in the same orientation as a D1.
Old November 26th, 2012, 03:18 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
the bolt holes for the mount/bushing are rotated 22 degree's toward the frame rail on a d90, where the are parallel to the frame on a d1.
here's my weld on frame bracket...
------ Follow up post added November 26th, 2012 04:21 PM ------
Originally Posted by Wolf Fabrication View Post
Swap over to X-Eng X-Joints and trailing arms and never worry about those bushings again.
sure it's a option, but they don't show them on thier website anymore...
Old November 26th, 2012, 04:23 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
Jeff, I have some good used genuine rubber bushings that came off my truck if you want to give them a try, or if you just need something to get you back on the road.
BTW, I also have RT trailing arms and have the same amount of thread showing with the nut torqued to spec. I believe they are longer than stock to accommodate spacers.
Old November 26th, 2012, 04:25 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Thanks man, I may take you up on that if it looks like it will take a while to get my replacements (whatever they end up being). I will give you a shout to let you know either way
Old November 26th, 2012, 05:09 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Dude, just switch to something with more articulation and don't look back - rose/jonny/heim/x-eng joints.
Semper Fi!
Old November 26th, 2012, 05:15 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
So my pic of the arms on the floor is of the old type. The new ones are the ones in fishEH's pic of Jake's truck. The difference is the joint at the axle. The new ones are adjustable at both ends.
Frank does HD Tie Rods and Drag links as well but I donít have a DL pic.
ID:	61620   Click image for larger version
Old November 26th, 2012, 05:21 PM
Wolf Fabrication
Sterling Archer
'08 D3
Frank does HD Tie Rods and Drag links as well but I don’t have a DL pic.
Damn, I need to do that upgrade.
Semper Fi!
Old November 26th, 2012, 05:41 PM
Wolf Fabrication
Sterling Archer
'08 D3
Just confirmed with X-Eng, his X-Joint/Arms are only temporarily unavailable.
Semper Fi!
Old November 26th, 2012, 09:37 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
That tierod is .250 wall 1.5 DOM with a .120 wall 1.75 sleeve, has tierod to heim adapters and has a guarantee for a free replacement if you bend it
It's for hardcore wheelin' and killing zombies after the apocalypse...
Old November 26th, 2012, 09:45 PM
I. Must. Have. It.
I'm assuming it's a "one free replacement" thing? Cause I can assure you we will find some way to bend them on the trails.
Old November 26th, 2012, 09:53 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
no, it's for the life of it...you bend it, I'll replace it, but you need to send the bent one back
drop me a pm with a number and I'll call ya tomorrow
Old November 26th, 2012, 09:55 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Damn Frank, why don't you advertise a little? People are always asking "who makes HD rods?".
Old November 26th, 2012, 10:01 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
tryin' not to take business from the guy's making shit who need to sell it to pay the bill's...
and I'm sure Chapman and Nomar will find something wrong with it
Old November 26th, 2012, 11:02 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Pic of one on a truck. Slightly different sleeve design but you get the idea..
Old November 26th, 2012, 11:17 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I lied, I do have a pic of a draglink. DL and TR are both on here...
Old November 27th, 2012, 09:24 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Do your tierod/draglinks use a stock thread for the heim joint or something more standard like 3/4"?
Old November 27th, 2012, 09:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That looks burly as hell! It must tighten up the steering feel a lot.
Do you have a site with prices/info or anything? Or email? Not in the market right now but will be next time things break.
Old November 27th, 2012, 10:11 AM
I guess from an crumb-crushing, mind-numbingly boring engineering standpoint, design methodology is to use a spherical joint in only a "double shear" application, which is a closed bracket. Ball joints are supposed to be used for "single shear" applications, or those in which only one end of the joint is attached to something.
Therefore, ball joints are the "textbook" application for tie rods, although they don't look as cool as spherical joints. If you notice, the first picture has a "capture washer" on the open end of the joint, which is designed to hold the tie rod to the knuckle in case the spherical joint cage separates from the ball (which they do)
Old November 27th, 2012, 10:35 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
3/4" heim...
------ Follow up post added November 27th, 2012 11:38 AM ------
Not running a true business, but operate under a LLC for liability...PM me here for info
Old November 27th, 2012, 10:58 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I guess from an crumb-crushing, mind-numbingly boring engineering standpoint, design methodology is to use the spherical joints only what is called a "double shear" application, which is a closed bracket. Ball joints are supposed to be used for "single shear" applications, or those in which only one end of the joint is attached to something.
If you look at the picture of the "pin", while it is single shear, there is a misalignment spacer machined into the piece that captures the center of the joint, also machined into the "pin" is a safety washer, even if the joint self destructs, the safety washer will hold the cage of the joint. These joints are not under heavy load in a steering tierod application and have a static load rating of over 28,000 pounds.
Please post up one picture of a failed QA1 hiem used in a tiered application.
They are trail tested, tried and true, made in America joints.
Rear trailing arm instalation jayz Defender Technical Discussions 9 August 31st, 2012 06:33 PM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 09:02 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Why not remove the inner bushing sleeve? ezzzzzzz Defender Technical Discussions 0 June 10th, 2004 07:00 PM
