top rollbar lights - Defender Source
Old January 10th, 2014, 10:14 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
top rollbar lights
Thinking of getting 4 driving lights to mount on the top windshield rollbar. Since these lights come in pairs, I assume convention is to wire each pair with separate switches and relays?
Old January 10th, 2014, 10:18 PM
Thats what I would do. If you want all 4 on at once you can use one switch operating 2 or 4 relays. Electric stuff is easy peasy if you plan things out.
Love the artwork!
Jeff types faster than I do.
Old January 10th, 2014, 10:24 PM
CaptMidnite
Daniel Choi
Love the artwork!
I've done some basic soldering and electric work, but I didn't know one switch could control more than one relay. Thanks for the info. Thanks for the thumbs up on the artwork!
Old January 10th, 2014, 10:34 PM
Are these going on a Defender or a VW Thing? Hard to tell from your drawing.
Old January 10th, 2014, 10:36 PM
Substitute your + switch wire where the diagram says to wire in the high beams.
Old January 10th, 2014, 10:52 PM
CaptMidnite
Daniel Choi
I should have drawn in the vent flaps!
Thanks for the diagram JavelinaDave. Does this setup allow separate control of each pair? Do I use a 3-way switch?
Old January 10th, 2014, 11:12 PM
No, thats for one switch operating all 4 lights at once. To control each pair you need to split the drawing above right down the middle and use 2 separate switches.
Old January 11th, 2014, 07:46 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
At first I thought it was a "Back to the Future" Defender, when the tires fold up under the DeLorean for flying...
Don't go cheap on your lights; no "Baja", get Hella, PIAA or something decent.
Personally, I think the old Hella 4000 looks best.
I dont really like the look of those square LED "pods" and "bars".
But I'm a traditionalist more than a modernist.
Rent my
Old January 11th, 2014, 09:13 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hahahahahahahaha!!
Attributed to Shayne...
Old January 11th, 2014, 10:03 AM
lrna04's Avatar
lrna04
Michael
1994 D90
I have each pair on separate switches, however I use 3way switches.
Middle position off
Forward is on with key on
Back is only on with key on + high beams. That way it's much easier to turn all the lights on/off with on coming traffic.
ht, lights, top
94 D-90 ST - Need rear shoulder seat belt bolt (at top of rollbar) down_shift Wanted 3 October 26th, 2011 06:18 AM
Fiberglass top for Soft Top? boshea Wanted 1 April 20th, 2004 04:53 PM
Fiberglass top for Soft Top? boshea For Sale - Parts 1 April 19th, 2004 04:23 PM
Tickford Top Forsale RoverWrecks For Sale - Parts 0 March 30th, 2004 01:52 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
