Top 200 TDi speed - Defender Source
Old October 28th, 2012, 11:35 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Top 200 TDi speed
So what is the normal top speed? I have a 1.4 TCase and I am 70 mph on the flat but 55 tops on the uphill.
I would love to have pulling power up hill at 60 mph. Any advice?
Old October 28th, 2012, 11:38 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Bigger injectors, mechanical tune, intercooler, the list can go on.
Old October 28th, 2012, 11:43 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Work with me on this and you might find yourself with reasonably priced set of wheels and tires.
Old October 29th, 2012, 12:02 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Throw a dura max in the beast!
Kidding. I have the same set up and that sounds about right. I have read about turning up the injector pump and making sure you monitor EGTs and get a bigger intercooler. There is a whole thread dedicated to the injector pump. It's a common pump Bosch VE so you can google it and watch videos on this (dodge ram I think).
Old October 29th, 2012, 01:06 AM
JohnsD90's Avatar
JohnsD90
I can't imagine the mild tune which should be a nice boost in power, will really skyrocket his Exhaust temps, thats more when you are pushing the injector pump and turbo to their limits, and i doubt the stock power of this motor anywhere close to the limit. Something to keep in mind is that no smoke is what you want, if it smokes its getting more fuel than air, the trick is to get the maximum amount of air possible to for combustion, and then have the right amount of fuel to match that, anything more than that is just wasted fuel resulting in smoke.
Also, stormer you may want to pull your intake manifold and clean it out (this i can help you with, I've never fiddled with tuning though), over time they get built up with large amounts of carbon deposits, and it really restricts air flow. I pulled my mine off of my Jetta and it made a world of difference in 4th and 5th gear, pulled much harder.
Old October 29th, 2012, 01:29 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
I have the same thing. That is why i am thinking of changing my stock intercooler for a bigger one.
Uphill the 200 tdi is to slow and can't keep up with other traffic. But that is the price we have to pay to drive a small diesel
Old October 29th, 2012, 02:20 AM
JohnsD90's Avatar
JohnsD90
Ill help you with whatever you want help with, but I've never tuned a motor, i usually outsource that, but changing an intercooler or pulling the intake manifold is something that is pretty easy to bang out.
Old October 29th, 2012, 03:22 AM
Bigger injectors on a 200tdi ? A better course of action would be new injector tips as they have a lifespan of only 80k. Egt's skyrocket with minimal fueling increases beyond stock. I had a defender 200tdi setup with a full width intercooler and pyrometer. The truck would run 75mph all day long (gps showed I frequently hit 85) running stock gearing with a 1.4 tcase and 285's and 4 inches of lift. Egt's would get up to 1200 on long grades but if you backed out for a few seconds they would drop and you could get back on it. It would hold 75mph on grades. Pump timing is also key to decent performance.
Taking the wastegate boost signal from the intake manifold rather than directly off the turbo outlet also makes a big difference. This makes the wastegate open based on true boost @ the intake valves as opposed to what the turbo is making before all the pipes and intercooler. Another easily done item is to shorten the actuator rod between the actuator and the wastegate to squeeze a little moore boost out of the turbo (200 doesn't make much boost). I ran a boost gauge on mine-also plumbed into the intake manifold and never saw more than 12psi . All of this is documented on the web to include "how too's" on this website and others including mine. Tuning a tdi engine should be considered manditory as the stock tune was "detuned" by design and fuel economy and power both typically increase when the engine is properly tuned. Once tuned correctly you will find yourself shifting earlier and not revving the crap out of the drive train in every gear, ie much more driveable/ satisfying experience.
Adjusting the valves every 12k is also key. As they wear they get noisy and don't open as far or as long which results in less fuel air getting pushed into the cylinder each revolution.
Old October 29th, 2012, 03:56 AM
Amazingly easy to push EGTs through the roof. Should be a mandatory piece of kit on every diesel
Old October 29th, 2012, 04:33 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
It should go faster on the flat but untuned and dependant on the steepness of the hill that sounds about right.
Mine's a bit faster -1.22 transfer box, standard axles and 235/85 tyres.
Mike Hammond
Old October 29th, 2012, 08:01 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You have a 4 cyl diesel pushing what 5,000 pounds. It is what it is. Yes you can do all the fancy stuff, Doug gave some good ideas, but in the end it is not going to be a v-8. Tire size makes a big difference and gearing. My D90 is much more lively than the 110. Weight makes a difference but the 4.11 compared to the 3.56 changes the truck. I am still able to do 70, no problem. However here in the mountains it does slow down on the large grades no matter what you do.
Land Rover 110
Old October 29th, 2012, 09:07 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
With 4.11s, 1.4 tcase, and 35s, I can cruise at 70 and it dogs out on hills, but I wouldnt want to go faster anyway.
Semper Fi!
Old October 29th, 2012, 09:32 AM
Stormer's Avatar
Stormer
JP
2008 RRSC
It's mostly the uphill speed that is a problem while on the Merritt Parkway/Freeway. Goes from 70 to 50 and dogs it.
Old October 29th, 2012, 09:40 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Hey I wanted those wheels and tires!!! I would adjust pump timing first. I had a 1.6TC in my 110 and it had plenty of speed and power on the hills. It is a little trial and error to find the sweet spot with the inj pump. Are you sure you do not need to bleed the fuel system?
Patches are for Pirates and pants, not a bulkhead and chassis!
Old October 29th, 2012, 11:12 AM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
can get my 90 on 33's up to 80 pretty easily, although it feels more comfortable under 75. I usually bog down on hills so I guess speed really depends on how big of a hill it is. figured I'd throw in my .02
Old November 4th, 2012, 05:44 PM
Stormer's Avatar
Stormer
JP
2008 RRSC
Once the dust settles and power returns to CT, we are definitely having a CT get together. I am pretty flexible on location. There are a few good spots here in Fairfield that pour beer.
I have little to no clue on adjusting the inj pump or bleeding fuel system.
tdi, top
200 Tdi Drivetrain roverx For Sale - Parts 6 September 8th, 2009 03:27 PM
200 TDI Airbox Complete (me thinks) SafariHP The Vendors Loft 4 November 20th, 2008 01:38 PM
FS: NAS Fiberglass Top, NYC area NASD90 For Sale - Parts 1 September 1st, 2004 05:17 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
