Tools Required for Water Pump Swap - Defender Source
Old September 10th, 2015, 11:02 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
4.0 Disco V8. I am away from all my tools and manuals and literally have to rebuy what I need for the job.
What's needed?
From memory:
Fan wrench (size?)
10mm and 13mm sockets with extensions.
10mm wrench
Breaker bar for tensioner (how does it attach?)
Semper Fi!
Old September 10th, 2015, 11:09 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
32mm for fan I think
15mm socket on breaker bar for tensioner
Old September 11th, 2015, 11:09 AM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
36mm for fan
Old September 11th, 2015, 11:23 AM
10mm and 11mm for the water pump bolts. Thread sealant for the ones that go into the water passages (long ones on driver's side.
Old September 11th, 2015, 07:14 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
Borrowed the 36mm fan clutch wrench from vatozone. Loosen the fan counter clockwise. Just replaced my viscous unit today. Use a calibrated torque wrench.
Old September 11th, 2015, 07:42 PM
I would not use a torque wrench unless you are replacing the bolts with new Genuine ones. The long bolts will almost certainly snap if you follow the factory toque spec.
Old September 11th, 2015, 07:46 PM
Wolf Fabrication
Sterling Archer
'08 D3
Agree. Water pumps are not something that generally require proper torquing of bolts.
Semper Fi!
'99 D2 Some Assembly Required $1850 Abrooks For Sale - Vehicles 16 July 5th, 2009 03:14 PM
ARB Winch Bumper - Suspension Mod's Required? wadaman Defender Technical Discussions 2 March 13th, 2009 02:38 PM
Amount of brake fluid required for renewal JFD Defender Technical Discussions 6 September 23rd, 2008 06:24 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
B-Pillar Picture Required CDN22 Defender Technical Discussions 11 May 11th, 2004 11:48 PM
