Tool Specs - Hub nut - Defender Source
Old July 9th, 2014, 03:31 PM
Ruedelesseps
Jon Atkinson
1985 110 MOD Pickup
Does anyone know what the tool specification is to remove the rear hub nut on an '85 110 is? Does the 52mm spanner work or is this only through '83?
Trying to replace the oil seals to keep differential oil from leaking from the rear axel. Any other tips on this job would be appreciated.
Thanks!
Old July 9th, 2014, 03:42 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
http://forums.lr4x4.com/index.php?showtopic=15073
Read this. Uncle George is RDS (Rovers Down South).
Old July 9th, 2014, 03:51 PM
to broaden your options, I use the hub nut tool from my old 79' CJ7 with Dana axles. perfect fit.
Mark Kellgren
KM4BOR
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
The actual size is 2-1/16". Uncle George probably has one, if not you can get them from the usual suspects.
Make sure you clear the breather as well. That causes alot of leaks, even when the seals are good.
-Jeff
like us...
socket works well to remove them, just watch that you don't over tighten them when reinstalling…
Old July 9th, 2014, 04:01 PM
here's an example http://www.quadratec.com/products/98...FVFp7AodsFQA7w
just google "jeep cj hub nut socket". I know it hurts, but do it.
Mark Kellgren
KM4BOR
pinion nut torque specs and seal question wantone Defender Technical Discussions 0 May 30th, 2012 12:11 PM
hub face to hub face axle length TexasD-90 Defender Technical Discussions 1 June 3rd, 2011 09:00 AM
hub nut tool(socket) muhley Defender Technical Discussions 9 April 18th, 2011 11:59 AM
front hub nut size? tkavan01 Defender Technical Discussions 11 May 22nd, 2006 06:06 PM
Hub nut! TwisteD90 Defender Technical Discussions 22 September 28th, 2004 02:00 PM
