tool info needed - Defender Source
Old March 31st, 2006, 12:34 PM
Rover- Girl
Guest
Posts: n/a
Question tool info needed
Will have a buddy of mine fix the front end (Drop arm/link & Tie rod ball joint assem.
I have all parts in hand..
My question...what does he need ( tool wise )
What are the common mistakes made and how are they avoided !?
Shortcuts/hints and Ideas to help him make the job easier and faster !?
Christine
Old March 31st, 2006, 12:49 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
19 mm wrench - pliers to pull cotter pin - Big Hammer - thats about it
Old March 31st, 2006, 02:21 PM
Hmm I think a puller would help allot to get the drop arm off, and if you are rebuilding the ball joint on it you will need a press or at least a small drift to tap it together with. You may also need a ball joint pickling fork. Sometimes you can get away with out any special tools, other times you end up breaking the special tool just getting things apart.
Old March 31st, 2006, 04:03 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
There are some horror stories about getting off the drop arm. Do a search and read up on it. I would start spraying pb blast right now... Personally, mine came off after breaking 2 pullers and finally using a torch and impact gun.
Electric Cooling Fan 97 info needed. WHITE RHINO Defender Technical Discussions 8 January 8th, 2012 02:11 PM
Rovertrack's Sewer Cap Info Needed Eric Siepmann Defender Technical Discussions 21 August 5th, 2009 11:28 PM
what tool needed to remove shocks? ditskovich Defender Technical Discussions 10 May 13th, 2009 03:36 PM
Info needed on Arb air locker. rustydefender Defender Technical Discussions 5 January 9th, 2005 03:46 PM
