Hello All,
I've been lurking on this board (this wonderful, wonderful board) for a few weeks now. Two weeks ago I took the plunge and purchased my first Rover. She's a 84' RHD D90 with the 300tdi and the R380. She's only been in the States since Feb and is from Scotland. I've been taking it easy on her till I could get her into my mechanic. I told him to look over everything and let me know what I was into. He hit me with a whopping $86 bill. I was thrilled, expected to pay big $$$$. The feeder lines on the top of the motor had to be replaced, that's why you can see the drips in the pics. I've already ordered new tires after reading a bunch on this site and I need to replace / remove to muffler. I have a short list of the other mechanical items that need to be address and I've been trying to do as much research as I can. First thing I'm trying to figure out is what the gasket is called that is located where the water-pump mounts to the block, I've attached photos. I have a slight coolant leak there. I'm also trying to locate an air-filter housing, as you can see mine is pretty messed up. I've looked at roversnorth, rovahfarm, roversdownsouth, but I can't find one. The speedo isn't hooked up, but I was wondering if the speedo in my dash can even be hooked up to the R380 trans? If so what do I need? I was under the impression that the one I have is mechanical and the one for the R380 is electronic? I also need braided diesel fuel line, but I imagine that should be easy to find. Any help would be great. And thanks to all of you for such an invaluable stockpile of information and expertise!
