Too good to be true? 4.0 head question - Defender Source
Old June 14th, 2016, 03:34 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
So I found out I have zero compression in cylinder #2 on my 1997 4.0 V8. The cylinder has been burning oil for years and recently had a misfire due to a fouled plug. Changed the plug and all was good. Now the other day on the highway it developed another misfire. Checked spark, all good there, and put in a new plug. Still nothing. Did a compression test last night and zero compression. 160psi on the cylinder next it but nada on #2.
So I am about to do a leak down test to see where the problem is but in the mean time I am searching for solutions. I am hopeful it is valves and not rings. If it is I will need to have the head rebuilt.
In searching ebay I found this link. Seems to good to be true for that price.
Any thoughts, experience or advice?
Land Rover Discovery 4 0 Cylinder Heads Complete Pair Cast HRC 2479 1995 1999 | eBay
Old June 14th, 2016, 03:46 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Pm'd
Old June 14th, 2016, 10:12 PM
Probably a bent exhaust valve from valve sticking. Did you have a CEL? The very late valves are supposedly much better about not sticking, but they are rare and megabucks new (pretty sure I have a set somewhere) $200 a head is about what it costs for a deck and rebuild. If they are not warped, you can clean, ream, lap, and put one back together in an hour or two. Make sure you have a good valve compressor. The reamer is helpful but not necessary and can lead to additional issues like oil usage. If it were me, I would ream the valve guides. I forget the spec but it is very minimal like a few thousands or something.
Old June 14th, 2016, 10:14 PM
Naplm00
Matthew
I got a set of 351w ford cobra heads reman for less, so I think it's probably legit
Old June 16th, 2016, 10:00 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks for the insight. Not sure what you mean by a CEL. But I pulled the valve cover last night and nothing looks out of place so we shall see. Gonna do a leak down test today to just verify it's not rings and then will pull the head. Compression on all other cylinders is really good. All are at 170-175 so that is promising.
Not sure if I want to rebuild the head or buy re manufactured ones in the interest of time. Would be nice to just order them and slap new ones on.
Old June 16th, 2016, 10:05 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
CEL=Check Engine Light
Old June 16th, 2016, 10:11 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Ahh yes. My CEL is on all the time due to a bad rough road sensor computer issue. But I did have the codes read and it said misfire cylinder #2. So I would assume the CEL was triggered.
Old June 16th, 2016, 10:35 AM
If it was rings you'd have huge smoke coming out the pipe.
Old June 16th, 2016, 11:15 AM
If its rings, a squirt of oil in the cylinder will raise the compression signficantly on the compression test. If it's valves, it won't.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 16th, 2016, 05:11 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Good point on the rings.
Did a leak down test today and it undoubtedly is an exhaust valve. So that is good.
I think I am gonna go for those rebuilt heads. I called them today and they seem totally legit.
Good price seeing as a local machine shop would charge about $250-$300 or so to rebuild the one head. Might as well do both while in there.
One more question for you all regarding a gasket kit. Atlantic British has one for like $119 but shows a ton of o-rings and other gaskets. I assume that is for totally rebuilding the top end. I am not doing that. So how many gaskets should I be replacing? Obviously head, valve cover, I need a new intake manifold gasket otherwise known as the valley pan gasket if I am not mistaken but other than that what else should I source?
Finally, what about head bolts? Do they need to be replaced as well?
Thanks for the help.
Old June 16th, 2016, 05:14 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Here is the photo of the gasket kit from AB.
Old June 16th, 2016, 05:28 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Found the answer to my head bolt question. They need to be replaced each time they are taken out.
Old June 16th, 2016, 05:52 PM
Not sure if he still does it, but Will Tillery used to sell heads that had already been rebuilt for a pretty good price.
Old June 16th, 2016, 10:26 PM
That is the kit you want. You won't use a few of them, but separately it would be more expensive. Buy genuine. The little round things are valve guide seals which the rebuilt head should already have.
Old June 16th, 2016, 11:27 PM
dont forget that front cover gasket either this is a perfect time to have your radiator serviced
Old June 16th, 2016, 11:55 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks for the help. I appreciate it.
Old June 17th, 2016, 07:30 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Does the front cover have to come off?
Too good to be true? '84 Defender 110 - not mine TELOS The Flea Market 9 January 31st, 2014 06:00 PM
97 for 17K too good to be true CDeWan The Flea Market 11 April 29th, 2013 08:54 AM
Too good to be true? emm4787 For Sale - Vehicles 7 February 15th, 2013 06:00 AM
This looks too good to be true... Just wash the rust away... IPSC_GUY Misc. Chit-Chat 1 December 27th, 2009 07:36 AM
Another Too Good to be True Story outfield Misc. Chit-Chat 0 October 15th, 2008 03:35 PM
