Too Cold for the TDI? - Page 2 - Defender Source
Old February 21st, 2015, 05:22 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
We got 10"+ of snow today so we've been driving all over town in the Tdi LWB.
Outside air temps in the upper teens and low 2o's.
The heated front windshield is best though for quick defogging...
Engine temps were good within 5 minutes of running and the Tdi/RRC combo makes plenty of cabin heat.
I'm almost glad that RRC seat heaters NEVER work because I'd be too hot...
Rent my
Old February 21st, 2015, 05:27 PM
I started my Tdi up today; 18*F -no glow plugs(still havent wired them up yet).
Fired right up!
Bet you can't say that about your 7.3 tdi
Old February 21st, 2015, 06:59 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Jeff
You are right about the cabin heat in RRC ! After about 5 minutes I can't run it on hi!
Enjoy your snow!
Old February 21st, 2015, 07:22 PM
Originally Posted by Red90 View Post
Do not ever let it idle cold to warm it up. It is very bad for the engine. Start it and drive it to warm up.
I know this isn't a Land Rover engine, but I seem to remember reading the owners manual for a friends Dodge with a Cummins, and I thought it said to hold the engine at 1500 RPM's until the temp gauge began to move before driving it in temps below freezing. This was a long time ago, so I may be mistaken about this.
Old February 21st, 2015, 07:44 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Well, I did take it up to Wintergreen last week @ about 12*F but I let it glow 3x before cranking.
It fired right up but it burned pretty blue smoke until it warmed up.
Then it didnt smoke at all.
Does your 7.3 smoke when cold?
Rent my
Old February 21st, 2015, 08:29 PM
Nope, get a little white when it first starts in subzero temps for 20 secs or so. Three cycles of those big ass glow plugs kills the 2 interstate 900cca batteries on mine. Twice on the winter romp trip I had to get a double jump. IE trucks on either side. I left it running all night twice. The key is to plug them in but that wasn't an option when staying in hotels with 4-6 feet of snow piled around the exterior of the building.
Old February 21st, 2015, 08:41 PM
1500 rpm is not idling. It is still better to drive as it gets the combustion temperatures into a safe range quicker.
Old February 22nd, 2015, 07:41 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Overlander View Post
I don't think so. Getting it started is the key. Only running issue is keeping the diesel from gelling in the lines. My primary filter is a racor with a bowl heater. The heater is always powered with ignition, but the elemen in the bowl turns on automatically when the fuel is below 45F (I believe that's the temp). Should be a bit warm going back to the tank. When you go farther extreme in temps (sub-zero), then you may need fuel line heaters, tank heaters, block and battery heaters if it's sustaining cold. But a heated filter, heated seats, synthetic oil, the right diesel mix (winter diesel), cabin insulation and a webasto are a good start to cold weather diesel prep.
damn
------ Follow up post added February 22nd, 2015 07:50 AM ------
We got 10"+ of snow today so we've been driving all over town in the Tdi LWB. Outside air temps in the upper teens and low 2o's. The heated front windshield is best though for quick defogging... Engine temps were good within 5 minutes of running and the Tdi/RRC combo makes plenty of cabin heat. I'm almost glad that RRC seat heaters NEVER work because I'd be too hot... .
Those low ceilings prob help a lot with cabin comfort. I was on the road about 10 hours yesterday in my 90. That sucker cools off just refueling.
Old February 22nd, 2015, 10:41 AM
sandman913's Avatar
sandman913
1985 110 200 Tdi
The tdi is new to me- well most things diesel. I'm learning, but how do I know if any damage is done?
Old February 22nd, 2015, 10:43 AM
you didn't do any damage idling 20 minutes a few times. Don't stress it
Mark Kellgren
KM4BOR
Old February 22nd, 2015, 12:59 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
2.5NA started at 5F with 15-20 seconds of glow plug. The oil temp stays 1/3 of the way to the middle (could be the oil cooler?) Is that okay? Water temp stays perfectly in the middle though.
tdi
best battery for cold starting 200 tdi Sandt Defender Technical Discussions 6 October 31st, 2012 08:01 PM
Cold Weather Starting the 200 TDI; Trials and Tribulations from Colorado paluskat Defender Technical Discussions 9 February 5th, 2011 03:58 PM
vent control too loose artm Defender Technical Discussions 2 April 19th, 2005 07:49 AM
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
OME shocks are too long on rear axle... wicks Defender Technical Discussions 5 October 6th, 2003 02:39 PM
