Tithonus Thread - Defender Source
Old September 8th, 2015, 10:15 PM
mdubs's Avatar
mdubs
Matt
1986 Tithonus Defender 110 ST
Tithonus Thread
I'd like to start a thread concerning improvements/additions you guys have made to your Tithonus rigs. I did a quick forum search and for some reason I could see any of the pictures you guys posted in the registry threads.
Couple of questions:
How hard is it to remove the fiberglass top (2 man job)? Is it impossible to store once it's off due to the size?
Are there any after market soft tops that resemble the NAS OEM ST? I was thinking something like the STs on some of the "special" ECR 110s seen on Copley's site. Think Badger could do one up?
How hard would it be to install a forward facing seat vice the side seats?
Has anyone tried to soundproof the interior or is it a lost cause?
Also I'm assuming no AC or radio, has anyone explored trying to add those options? What about a Tuffy-like box?
Any other owner experiences or feedback would be great-especially things to look for when shopping besides the usual spots
Thanks again, looking forward to hearing from you all
Old September 9th, 2015, 07:29 AM
A lot of that stuff isn't specific to Tithonus trucks and have been easily added in all types of defenders, like a forward facing bench seat. Good luck! If you're having trouble opening pics in the registries, try from a computer, as the mobile version has not been fixed. You can touch the thread at the top in mobile version and it'll open in desktop view.
Old September 9th, 2015, 08:00 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
I have done many of the things you have asked about. The tops are easily removed but requires 2 people because of the size. It store fine but is bulky. I used Dyna matt to do the whole cab and doors. Helped a lot. No AC but I installed a ruddy box with door cards to provide a stereo and a place for my speakers. I would ask Rivermike about his soft tops as there are like none that I have seen. If you have any questions please just pm me.
Old September 9th, 2015, 09:19 AM
moved the thread.
Also chris snell had a good thread about his build - maybe PM him and ask him if he'd un-hide it. He doesn't like soft tops with windows, but there was a good thread about them here. Badger will build you anything, but you'd have to get the truck to him or know of one nearby he could use.
http://www.defendersource.com/forum/...top-63042.html
Old September 9th, 2015, 10:35 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Conditioning of the interior:
I have more pics but it's a PIA to load them with the mobile app
Cheers
ID:	129240   Click image for larger version
ID:	129242   Click image for larger version
ID:	129244   Click image for larger version
Old September 9th, 2015, 10:45 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Soft top is exmoor purchased at RN. I lowered the roll cage about 2 inches by cutting and welding in place.
ID:	129249   Click image for larger version
Old September 9th, 2015, 10:49 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
What dash unit is that? I've seen it before but can't remember the name.
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old September 9th, 2015, 11:09 AM
Tribe's Avatar
Tribe
Pablo Cocito
1987 Tithonus 110
Raptor Engineering. I purchased it at urbanlandcruisers. It was a blank model
Old June 28th, 2016, 08:40 AM
smkdds2015
Matthew Kelly
1984 Tithonus 110
I'll be taking off my hardtop this weekend - I'll document the process and see if I can help anyone else thinking about doing the same thing!
Old June 29th, 2016, 03:16 PM
MyLeftyLandies
Gary Patterson
1990 LHD Tithonus
Its pretty straight forward. Once you undo the bolts above the door where the roll cage turns inside, lift the front section of cage up and forward as it pivots at the bottom of the windscreen. It sounds obvious now but we were about to undo those bolts too and there's no need!
Good luck.
Name:	Sean Surfer.jpg
ID:	152805   Click image for larger version
Name:	Sean crop coolers.jpg
Old June 29th, 2016, 09:35 PM
mdubs's Avatar
mdubs
Matt
Looks good! How long did it take? Obviously a two man job right?
Old June 30th, 2016, 06:52 AM
MyLeftyLandies
Gary Patterson
1990 LHD Tithonus
It is really. You could probably do most of the bolts on your own but then you'd need a hand with the final stage. The rear door is easier to remove with 2 people too. In other news...I bought a TUM ECM cover on impulse and now I'm scratching my head how I might be able to adapt it to fit. It doesn't seem to secure in the usual way...
Old June 30th, 2016, 12:47 PM
smkdds2015
Matthew Kelly
1984 Tithonus 110
Thanks for the info and pics! I've seen soft tops for sale with additional hardware - is that a must for attaching a soft top, or can it be secured without it?
Old June 30th, 2016, 06:12 PM
MyLeftyLandies
Gary Patterson
1990 LHD Tithonus
Tith soft tops need all the bits to secure it over the driver compartment and to the top of the front windscreen panel. What I need to fit the one in the photo though is anyone's guess.
Old July 2nd, 2016, 07:17 PM
neo812's Avatar
neo812
Kris
1985 Tithonus
Here's my contribution to the Tithonus thread. Mine is partially dismantled as all good Land Rovers should be.
Rover chrome is being applied to the roll bar and rear seat brackets and a few other things. Thus proving ,to a few certain people ,that I can in fact own a Defender without completely taking it apart to the frame.I view this as light maintenance ,not rebuilding.
Name:	2016-07-02 15.54.50.jpg
ID:	152934   Click image for larger version
Name:	2016-07-02 15.54.43.jpg
Old March 5th, 2017, 05:56 PM
mdubs's Avatar
mdubs
Matt
More questions
Now that I've actually bought a Tith, couple of questions. The lights are obviously a lot different than regular Defenders. I was playing around with them the other night to see what all the switches do. When I switch it all the way to the left all the "normal" lights come on (back and front). But when I switch on the high beams, only the Left light goes bright and the Right headlight goes completely out. Without the high beams, both headlights work. Is this a Tith quirk or do I have a wiring problem?
I also want to eventually cut holes in the bumper to add fog lights and make it look like a '94 NAS bumper. How hard would this be to do (cutting/wiring, etc.)?
I've got some surface rust on a couple of places, what's the best way to stop it and eventually get rid of it?
I would like to move the tire to the rear, but don't want to spring for a new hood (yet). Any suggestions for cutting off the tire mounts on the existing hood?
Would like to freshen up any easy maintenance areas, could you guys make some suggestions? I'm thinking I need to check the timing belt, etc.
Anyone know where I can pick up the overhead ribs for the cage?
Last one, I'm interested in tracking down the history of what my truck was used for in the British military. Any idea of how to look into that?
Old March 5th, 2017, 06:15 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
The tyre mount is just bolted to the underside on the bonnet, save all the bits you may one day find a use or somebody will want it.
------ Follow up post added March 5th, 2017 05:17 PM ------
I will dig out the info you need to get the history, is the M.O.D asset plate still fitted?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 5th, 2017, 06:26 PM
mdubs's Avatar
mdubs
Matt
Where is that plate located?
Old March 5th, 2017, 07:16 PM
MyLeftyLandies
Gary Patterson
1990 LHD Tithonus
Re the headlights, you have a wiring problem (or perhaps just need to change the bulb?) They should work as normal once you switch to the left. BTW, if you find you lose your indicators/brake lights/horn then jiggle that central light switch before you do much else. You will probably find the aforementioned come back to life. (Not that you asked about that. Bonus random info...)
Old March 5th, 2017, 07:32 PM
roverman2010
1985 LR 90 200Tdi
Is not a plate riveted to one side of the seat box? Maybe another tith owner can tell where it should be.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Tithonus? solarguy Misc. Chit-Chat 60 March 26th, 2016 04:32 PM
another ex-mod tithonus :: 1986 Land Rover 110 tithonus FFR coteya Defender & Series Truck Registry 0 March 30th, 2015 11:32 PM
Tithonus hard top to soft top solarguy Smaller Projects 17 January 13th, 2013 05:12 PM
Tithonus 110 Exmod soft-top ontheway Defender Technical Discussions 7 June 29th, 2012 04:39 PM
» Defender Registry
RHD 90
Arran73
Sandy
Sandy
Add your Defender
