Tithonus Soft Top Installation Questions - Defender Source
Old July 13th, 2014, 08:31 AM
dlbriller
Doug
1987 ex-MOD 'Tithonus' Defender 110
Two questions for those who have converted from a hard top to a soft top -
1. How does the roll cage connect to or through the rail that sits above the door. My understanding is that you use parts RRC8386 and RRC8387 but there's no hole for a through bolt to connect into the roll cage as there was for on the hard top.
2. Where do you get the snaps that run slide into the same rail and snap down the top. Are these standard Land Rover part number?
Thanks in advance for your expertise.
Old July 13th, 2014, 09:49 AM
BOBCAT110's Avatar
BOBCAT110
Ken Jagolta
94 d-90
You need to drill holes in those drain channels.
Old July 13th, 2014, 12:22 PM
dlbriller
Doug
Thanks, I figured that was the case. Any suggestions on a source or part number for those snaps?
Old July 14th, 2014, 01:10 PM
dlbriller
Doug
For the next person looking for these snaps - part number is RRC8763, available from the usual UK based sources.
Old July 14th, 2014, 04:25 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Doug,
I just did this about 6 weeks ago. I had to hack the horizontal door frame piece. It was too thick where it connected to the roll cage. I noticed it when I was dry fitting everything and the door was warped against the seal. Can't take pics right now because it's pouring out.
I got my parts from PA Blanchard. The vertical door frames were completely bare, but had holes for the loops that hold the small Velcro straps on the top. These loops are the same loops on a Series near the tailgate. Some call them staples. I got some from Rovers North. Then I found them on Rovah Farm. Apparently the ones I got were galvanized gold.
Neil
Old April 10th, 2015, 07:13 PM
obone's Avatar
obone
Jim
1987 MOD Defender 110
Just wondering which brand and model of soft top did you buy and how is it working out? I am looking to take off the hard top.
Old April 10th, 2015, 08:12 PM
hmmrbrg
HMMRBRG
1972 SIII 109
Is there a canvas top for the Tithonus or only the PVC?
Old April 10th, 2015, 10:54 PM
Wolf
installation, soft top, tithonus, top
Tithonus Soft Top with Sides that Roll Up? spammer Defender Technical Discussions 27 November 23rd, 2013 07:28 AM
Wolf/Tithonus soft top for 110 chris snell Wanted 9 April 27th, 2013 12:41 PM
Tithonus hard top to soft top solarguy Smaller Projects 17 January 13th, 2013 05:12 PM
Tithonus 110 Exmod soft-top ontheway Defender Technical Discussions 7 June 29th, 2012 04:39 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
