Tithonus Roll cage - Defender Source
Old April 26th, 2016, 04:49 PM
Bpgt3
none
Tithonus Roll cage
Hey all. I did a search and didn't quite find the answer. Read the "So how effective is the SD Roll Cage?" to no avail.
Looking to put a full rollcage on my 86 tithonus. Having trouble figuring out which one is correct for fit and the hardware needed. Any help pointing in the right direction would be great.
Old April 26th, 2016, 04:55 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
What happened to the SD full roll cage that was fitted to your truck during the Tith refurb process?
Old April 26th, 2016, 05:00 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Here is a Wolf cage, it looks survivable.
Name:	SD Cage1.jpg
ID:	148153   Click image for larger version
Name:	SD Cage3.jpg
Name:	SD Cage4.jpg
Bpgt3
none
Great question. Bought it without one. It did have a metal hard top, not the FG ones also. Just getting into the MOD and Tithonus history and what not.
Did they come out of the program with an internal rollcage and a fiberglass top?
Old April 26th, 2016, 05:14 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Yes they were fitted with an external/internal beast of a cage and will only work with a soft top or the really tall goofy gel top that most ditch for a soft top. They also had some bracing fitted around the tub as well. There may be a Tith cage or two floating around.
Old April 26th, 2016, 06:18 PM
The Dro
Dro
1988 Ninety
Can you post pictures of your truck
Old April 27th, 2016, 08:41 AM
Bpgt3
none
Thanks for the replies.
So does that mean there are no prefab ones available? Do the Wolf or SD cages fit the Tihonus ones or do I need to get one custom made?
Do both those companies have branches in the US? Sorry for all the questions.
Old April 27th, 2016, 09:00 AM
Contact Safari HP. They had a tube plastic top in their shop. Wonder if they removed the cage from it as well.
Old April 27th, 2016, 09:51 AM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
No they came from Bobcat110 and he left the cages on the trucks.
Old April 27th, 2016, 10:20 AM
The Dro
Dro
1988 Ninety
Brian,
The Tithonus roll cage mounts as follows:
The main roll cage bar mounts in (2) two different places; At the rear bulkhead (Pics 1 and 2) and through the floor panel to the outriggers (Pics 3 to 6).
At the front it uses a bracket that's attached to the bulkhead (Pic 7).
They do not have the A pillar support like the NAS or SD/P&P (Pic 8)
The rear hoop is a joke... It mounts with two bolts to the capping.
ID:	148191   Click image for larger version
ID:	148193   Click image for larger version
ID:	148195   Click image for larger version
ID:	148197   Click image for larger version
Old April 27th, 2016, 04:28 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Minor hijacking for a question here. I'm about to install a roll hoop, really just for seatbelt mounting, no illusions of structural integrity.
But this corner piece that rivets in along the bulkhead and floor, when tucked in far enough to rivet to the outer edge is blocked by the top lip. It's hard to tell jn your image if it clears the curve of the top edge of the tub
My predicament:
This one's a bit abstract but it's the view from the front and middle of the truck, showing where the plate resides when it's flush with the bulkhead AND clears the upper lip. You can see how far it is from the putter edge.
What do I do??! Haha.
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old April 27th, 2016, 06:36 PM
The Dro
Dro
1988 Ninety
My predicament:
You probably will need to cut it.
I had to cut mine.
Old April 27th, 2016, 06:39 PM
The Dro
Dro
1988 Ninety
I left my external drive in the office and cannot show you mine.
But this is pretty much the same.
Old April 27th, 2016, 06:50 PM
The Dro
Dro
1988 Ninety
Ha! Found it
Old April 27th, 2016, 07:38 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Originally Posted by The Dro View Post
Ha! Found it
Perfect, so I'm not a dummy. Hole saw here I come.
Old April 27th, 2016, 10:05 PM
The Dro
Dro
1988 Ninety
Well... I wouldn't go that far
Seriously, I have one if you need it.
cage, tithonus
Tithonus roll cage (trade) PabloCocito For Sale - Parts 13 February 27th, 2016 11:11 PM
another ex-mod tithonus :: 1986 Land Rover 110 tithonus FFR coteya Defender & Series Truck Registry 0 March 30th, 2015 11:32 PM
NAS Roll A bar roll cage and front under wing supports defenderholty For Sale - Parts 6 August 9th, 2014 05:49 PM
Tithonus Roll Cage On A Ninety javelinadave Defender Technical Discussions 1 August 30th, 2013 05:46 AM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
