Tires on Boost Rims - Defender Source
Old April 16th, 2010, 01:54 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Tires on Boost Rims
I am in need of some new tires and have some Boost rims that I'll be putting the new tires on. The suspension is stock but I will eventually be replacing the springs/shocks and it will probably have a 1" lift with the rubber shock tower mounts I'll be using. But the suspension will be stock for the most part.
I'll be honest and say this Defender sees mostly asphalt but occasionally gets out for a few days of off roading. So I have been looking to just get BF Goodrich All Terrain TA's. Any other tires out there people like that have good street manners and still decent off road?
And lastly what is the best size to go with for Boost rims with a pretty close to stock suspension?
Old April 16th, 2010, 02:38 PM
specops1526's Avatar
specops1526
Beluga '97 90
try 265/75/16 BFG KM2s. I think any larger will rub since you're not quite at a 2" lift.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 16th, 2010, 03:17 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Stock tire size is 265/ 75S / R16 right?
Old April 16th, 2010, 03:27 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
correct
Old April 18th, 2010, 08:12 PM
235/85/16 Dunlop Radial Rover RT's
Old April 18th, 2010, 08:14 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
235's are too thin for rover aluminum rims.... 265 is the minimum..
285 / 75 look really nice with a small lift... I have pix of that setup
Legend in My Own Mind.
Old April 19th, 2010, 01:15 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
If you have time to post a pic that would be great. My plan is to get tires put on later this week.
Old April 19th, 2010, 07:33 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
If you have any questions, shoot me a PM..
ID:	26772   Click image for larger version
Old April 19th, 2010, 07:58 AM
I call bullshit
Old April 19th, 2010, 09:06 AM
285/75's look great on the boost wheels.
Old April 19th, 2010, 09:10 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Originally Posted by rover4x4 View Post
I call bullshit
Have you seen 235's on Alum. rims? I have made this mistake in the past for a project..... The rim ends up being Wider then the tread on the tire... It looks stupid... I would not go smaller then a 255 on one of those rims..
If you are going to give advise, have the knowledge/experience to back up your statement... (for the board and members sake.. )
------ Follow up post added April 19th, 2010 09:11 AM ------
I actually have a set of Boosts for the white truck.. they will go on in the near future..
Old April 19th, 2010, 10:54 AM
rovertrader's Avatar
rovertrader
Dale
255/85 is a good choice, as the 285s sometimetimes rub IF not lifted. The 255 is 33.3" while the 285s are 32.8", but the 255 is an inch narrower, giving a good fit and no rubbing stock height, and look sweet with 1 to 2" lift.
Old April 20th, 2010, 12:13 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
I have 285/75s on the D90 with stock suspension and bump stops. They rub on the radius arms, the rear tailpipe hanger of the Borla and slightly on the inner fenders at the front in a very few extreme articulation situations. It may be partially because I have Toyos and they have a very agressive sidewall patttern though. That said I think the size fits the look of the truck very well. Pic 1.
When I got the truck it had a nearly new set of Mitchelin LTXs in the stock 265/75 size. I think they looked too small and wimpy for the truck. Partly because of the type but also just because they looked too small. Maybe stock BFGs would look better/larger because of the more aggressive tread pattern? I must admit they where great on road, but the type of use I put the truck to, thay had to go. Pic 2.
Last pic is of my D1 LSE with 235/75s on Boosts. looks OK on the Disco, but I think they would look silly on the D90. Pic 3.
Its all perception though.....
YMMV
Ian
ID:	26810   Click image for larger version
Name:	Skinny Tires.jpg
Old April 20th, 2010, 07:26 AM
Im pretty sure that new Defenders come with 235/85's. I've never noticed the rims being wider than the tires?
Old April 20th, 2010, 08:13 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Not sure if you can notice the rim being wider then the tread or not in this pic.....
Old April 26th, 2010, 10:41 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Thanks for the advice everyone. I decided to keep a stock look and went with the 265/75/16 with the boosts.
Old April 27th, 2010, 02:00 AM
specops1526
Beluga '97 90
Nice truck. Looks good. Looks like you're missing a front crossbar on that SD rack?
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 27th, 2010, 03:43 AM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
I am missing a crossbar and have been trying to track one down. I know ECR has them but I can't afford what they want for it.
Anyone out there want to sell me one?
Old April 27th, 2010, 05:52 AM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
This is correct.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old April 27th, 2010, 09:42 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
7in rim width approved tire section width sizes courtesy of the RMA:
195-275
...also simple math prevails here
235 divided by 25.4= 9.25
A 235 section width tire is 9.25in wide, a 5 on 6.5 land rover alloy is 7in wide, 9.25 > 7.00
Even accounting for production differences in measured tire size a 235 tire is never going to be too narrow for a 7in wheel.
boost, rims, tire, tires
99.9% new tires on stock rims januconn92 For Sale - Parts 8 June 14th, 2005 12:25 AM
Shipping tires and rims d90Monkey Defender Technical Discussions 4 October 29th, 2004 05:26 PM
Rims & tires for sale revor For Sale - Parts 0 July 7th, 2004 12:44 AM
what could I get for my tires and rims? Rick Carlisle Defender Technical Discussions 7 November 21st, 2003 07:24 AM
