Tires and Wheels - Defender Source
Old December 13th, 2005, 02:05 PM
Rob
rob
1997 D90
Tires and Wheels
Thinking of running 33x12.5x15 tires on 15x8 rims....with stock suspension any thoughts on rubbing etc? thx
Old December 13th, 2005, 05:52 PM
scoloco's Avatar
scoloco
'94 D90 ST
I dunno. I'm running 285/75R16 on stock alloys with OME springs. Stuffs well.
My OME springs didnt really net me much height (I measured before and after, rear went up ~2" at the hitch, front unchanged). YMMV on this.
Your wheels/tires will have a different offset and so will likely stick out a wee bit more than mine. Dont know how much more. Worst case rubbing on the flares. I dont remember how much room I had with my tires stuffed, I recall plenty. YMMV.
But then there is the question of how often you are going to really stuff the tire?
Old December 14th, 2005, 09:57 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
I'm running 285/75 R 16 BFG AT/KO on my stock alloys with the 1.25" Alum spacers to get more width, however, no lift whatsoever (the truck is a D90 soft top that has been lightened to the max...no rear seats, etc...)
I do get some rubbing, but nothing drastic...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old December 14th, 2005, 11:01 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Rob, you should be ok. I am running 35x12.5 on the same rims with a 3" lift and they only rub a little on the rear wheel arch when fully compressed. You would prob be a little better with a 1.5 or 2" lift though. Might look cooler too..
Legend in My Own Mind.
tire, tires, wheel, wheels
Set Of 5 Black Steel Wheels And Tires jonathon For Sale - Parts 3 August 4th, 2005 01:45 PM
Tires and Wheels Jeremy Keith For Sale - Parts 6 July 12th, 2005 12:25 AM
tubless tires on tubed wheels asurover Defender Technical Discussions 2 February 3rd, 2005 01:30 PM
110 steel wheels and tires artm For Sale - Parts 3 January 21st, 2005 09:06 PM
Wheels & Tires roverboy For Sale - Parts 0 March 10th, 2004 03:13 PM
