Tire thread: interco ssr-41r or yellowsea 9.00-16 - Defender Source
Old April 27th, 2016, 09:01 AM
Naplm00
Matthew
Looking for tall and skinnys again and trying to choose between the following:
Interco ssr in 35x10.50r16 these are radials
And
Yellowsea Michelin xzl knockoffs, 9.00-16, I think these are bias ply
------ Follow up post added April 27th, 2016 09:03 AM ------
I'd probably have to sipe the yellowsea tires for wet traction..
Old April 27th, 2016, 09:36 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I'd vote for the SSR's myself but they look to be an extra $100 per tire. I liked my SSR's in the 285 size I had on my 90.
What is the weight of the Yellowsea's?
Old April 27th, 2016, 09:45 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Why not real Michelin XL's 900R16?
900R16 New Michelin XL Tire Tyres | eBay
Old April 27th, 2016, 09:47 AM
Naplm00
Matthew
Yellowsea are 90lbz a tire
------ Follow up post added April 27th, 2016 09:48 AM ------
I think they are rated for a vehicle way heavier than the defender, and just not a fan of the look. Have you used them?
Old April 27th, 2016, 09:50 AM
JohnsD90's Avatar
JohnsD90
Found them after I bought the KM2's, although not sure I want to jump up to a 36" tire. Though at my rate I'll need tires in a year haha.
Old April 27th, 2016, 09:51 AM
Naplm00
Matthew
Same here., I really want taller, but I know I'll need a 1.4 case I'm running a 1.2 disco case right now with a 200tdi
Old April 27th, 2016, 09:55 AM
That is a real apples and oranges choice! The SSRs will do well is pretty much everything. The XZL style tires will do well in mud and be horrible everywhere else.
rovertrader's Avatar
rovertrader
Dale
I ran the 35/10.50 SSRs for years and had no complaints! I like the 8.25 XZLs but they do need siped and are very stiff. The SSRs were acceptable on road as well- I also ran them on my H-1 way back when...
Old April 27th, 2016, 09:57 AM
Naplm00
Matthew
Good feedback peeps, I've never owned intercos butmaybe I shall.
Thank they will squeeze onto disco spare 16x7?
Old April 27th, 2016, 10:06 AM
I loved the SSRs. Great traction in everything, even pretty good on ice. Not that noisy and smooth.
They will fit a Disco rim, but the backspacing is not the best for a Defender. You will probably hit the rear spring mounts on a 110. An aftermarket 7" rim would be the best choice.
Old April 27th, 2016, 10:45 AM
Both will deafen you.
Old April 27th, 2016, 10:48 AM
Naplm00
Matthew
Lol yea, well my truck has a unruffled side exit exhaust. Noise isn't an issue here
Have you had SSRs? I had them and could not hear them above the the rest of the Defender noise.
Old April 27th, 2016, 10:53 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
With a 35" tire I would probably look at 4.1's in the diffs so low range isn't thrown off either.
------ Follow up post added April 27th, 2016 10:54 AM ------
Yellowsea are 90lbz a tire ------ Follow up post added April 27th, 2016 09:48 AM ------ I think they are rated for a vehicle way heavier than the defender, and just not a fan of the look. Have you used them?
90 lbs for a tire alone is heavy. Interco site says the skinny 35's are 72 lbs. That is a huge difference as its outside rotational weight.
Old April 27th, 2016, 10:55 AM
I would try the tires first. I did not have a problem swapping to the 34s.
You will have to trim the flares and have taller rear bump stops.
Old April 27th, 2016, 10:59 AM
I have 34 tsl's on wolf/nato wheels and used to have trxus 255.85's on my NAS 90. Admittedly no I have not run SSR's.
Old April 27th, 2016, 11:00 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I loved the SSRs. Great traction in everything, even pretty good on ice. Not that noisy and smooth. They will fit a Disco rim, but the backspacing is not the best for a Defender. You will probably hit the rear spring mounts on a 110. An aftermarket 7" rim would be the best choice.
When I tried mounting my 315's on Disco spares on the back of the 110 it hit the spring mounts where it cleared on my 90.
Being a 10.5" wide tire vs the 12.5" of my MTR/K the SSR may actually work with the clearance.
------ Follow up post added April 27th, 2016 11:03 AM ------
I would try the tires first. I did not have a problem swapping to the 34s. You will have to trim the flares and have taller rear bump stops.
Be prepared to have people posting you need a 4"+ lift to run those SSR's, haha
Old April 27th, 2016, 11:08 AM
You have to watch the contact at full articulation which depends on your suspension setup. It is also affected by the springs you are running. Stiffer springs push the articulation point down and make the sidewall more likely to hit the spring mount.
The other thing is that, although, these are only listed at 10.5" wide at the sidewall, the tread is a lot wider than a "normal" tire and this causes rubbing issues that you won't get in other tires. The actual specs are 35.3" diameter, 9.0" wide tread and 11.1" wide sidewall.
Old April 27th, 2016, 11:12 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
When I went from 255 KM's to 285 SSR's it was a rougher ride and heavier / slower road feel but not much change in noise.
Old April 27th, 2016, 11:22 AM
rovertrader
Dale
I did run 4.11s asa mentioned above, extended bump stops and flare trimming- but all worth it to me. I don't recall noise being an issue even on Interstate. But after all those years in Defenders I can't hear anyway... Saves lots of money on stereo equipment!!
90, tire
Tire Review: Interco TSL SX 32x11.5x16 sonoronos Defender Technical Discussions 40 May 7th, 2012 09:50 PM
5 each 35x10.5x16 Interco SSR's w/steel NATO's Cirbo For Sale - Parts 1 December 10th, 2007 08:12 PM
Interco Super Swamper SSR's for Sale Barnett Childress For Sale - Parts 1 October 24th, 2006 06:09 PM
Interco TSL/Thornbirds NashvilleRedD90 Defender Technical Discussions 5 May 27th, 2005 08:12 AM
