Tire Sizes - Defender Source
Old February 8th, 2005, 06:57 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
Tire Sizes
Right now I have 265/75R16 BFG AT's and they are worn out so I am trying to decide on what size I want to go up to (I am also going to do a two inch lift in the future). I think the tires I am going to use are Interco TrXus Mud Terrains so I am trying to choose between 285/75R16 - 33x12.50R16 - 34x12.50R16. If I run one of those tires will I have any rubbing without a lift? Also since I am going to do a two inch lift what size should I use? And will a 12.50 tire fit on 16x7 rims for now; I am going to put on 8 inch wide rims later on.
Old February 8th, 2005, 07:12 PM
255/85/16 BFG MT's
Old February 8th, 2005, 07:34 PM
285/75/16 will just fit depending on your backspacing.
The other sizes will require trimming.
Spring lifts do not affect tire clearance.
The 7" rim will be OK, but depending on backspacing you may have clearance issues inside the wheels.
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Tire Sizes Kimos Defender Technical Discussions 12 December 1st, 2004 11:53 PM
