Tire size question - Defender Source
Old December 26th, 2014, 02:46 PM
toona's Avatar
toona
Toona
1994 D90
Tire size question
Will 285/75/16 KM2s fit on a stock no lift 90 without rubbing?
Couldn't find in search
Old December 26th, 2014, 02:57 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Depends on who you ask.
I say you can run it even with a big 285 (SSR). But you might need a longer bumpstops and some wheels spacers up front to keep your turning radius.
Old December 26th, 2014, 03:13 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
yes but will limit turning radius .... you will need to adjust bump stops....
good luck with your search
Old December 26th, 2014, 03:19 PM
It is a maybe and will depend on the rims.
Old December 26th, 2014, 03:45 PM
thames's Avatar
thames
Paul Thames
'97 D90 SW
285/75 R16 BFG All-Terrain T/A KO2 rubbed the front radius arm on tight turns, WITH a 2 inch OME lift on my D90 SW. I was going to ALTERNATE the new AT KO2's on the original alloys, with my 8.25 XZL's on AR4636 steel wheels (I have a Staun Internal Beadlock issue to sort out on the latter). Just tried it last week with one wheel/tire on R front, no spacer, similar (within 1/2 inch) tire height. I don't know if others have used spacers, had hoped not to and may just get 255/85/16 KM2's for the alloys. New AT's skip that size. I think Bill Burke runs that size in a Mud Terrain on a lifted truck.
Old December 26th, 2014, 03:47 PM
toona's Avatar
toona
Toona
1994 D90
Very helpful, thank you
------ Follow up post added December 26th, 2014 04:50 PM ------
I should clarify I meant on standard 16" freestyle or boost rims
Old December 28th, 2014, 04:53 PM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
I have 285/75 R16 KM2s and they ride very nice. However, I would recommend a smaller size because when I turn all the way, my tires make a rubbing noise. However, when I checked with the wheel turned all the way, nothing was rubbing. Even a shop checked. Either way, get one size smaller and you should be fine.
Old December 28th, 2014, 04:57 PM
285's fit w/o lift just adjust your steering stops and make your turning radius even more abyssmal 255's are similar in height marginally narrower and will give you an improved turning radius over the stock 265s.
Old December 28th, 2014, 06:03 PM
Ben01
Ben
Defender
265/75/16 is great and will have the same look you are going for.
Old December 28th, 2014, 07:06 PM
toona's Avatar
toona
Toona
1994 D90
Thanks all, appreciate the input. I've decided to go with 265/75/16 on boosts.
Actual Tire size? revor Defender Technical Discussions 8 July 8th, 2004 10:10 AM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
