Tire Size Poll - Page 3 - Defender Source
View Poll Results: Tire Size Survey
33x12.5x15 4 2.34%
35x12.5x15 5 2.92%
235x85x16 41 23.98%
265x75x16 24 14.04%
255x85x16 48 28.07%
285x75x16 35 20.47%
305x70x16 2 1.17%
315x75x16 2 1.17%
7.50x16 15 8.77%
Other 8 4.68%
Multiple Choice Poll. Voters: 171. You may not vote on this poll
Old November 23rd, 2015, 12:27 PM
CDN83
Mark Lolley
Defender 90
Tire Sizing
I have a '94 Defender 90 with stock 265x75x16 tires on them right now. I have not changed the suspension and want to know what size tires can I go up to without causing problems; 285x75x16?, 295x75x16? 305x70x16?
Old November 23rd, 2015, 12:37 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Trouble meaning rubbing or breaking axles and falling outside of an ideal power band?
Old November 23rd, 2015, 01:41 PM
The stock suspension is well worn. The springs have sagged leaving you with less clearance than you had new. If determined to stay stock height and ride quality get more LR springs, plus Bilsteins, plus replace any worn suspension bushings. That will give it as tight a ride as possible.
As for tires, as is I wouldn't do anything. With new springs, 255/85-16 and adjust the steering stops to accommodate the taller fatter tire.
Old November 26th, 2015, 09:22 AM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Running 6-ply 9/32-16LT TSL Bias Ply at about 30 psi hwy/12-20 psi trails. Love them. Little squirrelly on the highway, but fine as long I'm not in a hurry (which I rarely am) they handle just fine. On the trails they are like tank tracks. Scramble over some stuff with open diffs that folks with lockers and KM2s were winching through. Open Diff was more of a limitation than the tires. Putting in rear Detroit Locker/ front Truetrac combo right now. Can't wait for the results. Click image for larger version
Old November 26th, 2015, 09:36 AM
rovertrader's Avatar
rovertrader
Dale
Taller yes, fatter no, about 1/2" narrower- and about 1.5" taller....
Old November 26th, 2015, 11:13 AM
i was able to run my steering stops in a bit when i moved up to the 255/85, mine rub the rear eyebrows at full tuck. 37" look good with the flares removed
Old November 30th, 2015, 03:02 PM
redline_r
Ridwan
1986/Land Rover 110
I've been running 265/75/16 on my dd 110. Pretty much only road use, and the 265/70/16 Yokohama are a good bit cheaper than the 75s.
I know I'll be revving a bit higher, and sitting about an inch lower. Will this look silly? Yes--it matters OTH, I should accelerate a wee bit faster, and that NA needs all the help!
Any photos/thoughts on 265/70/16 on a 110?
Old December 28th, 2015, 02:01 PM
RickM
Rick Mabus
95 D-90 ST
I would love some feedback here as I am struggling with what I want to do.
I am running 285/75/16's on steel rims that have a bit wider backspacing. They don't rub so I am good. They are currently the older MTR's.
I need to replace them and struggling with what to do. I want a tire capable of doing some good off roading, but to be honest, drive this truck on pretty days in Dallas. Here is my list.
-Goodyear Duratrac E ratings (although the sidewall ply has me concerned, as I think it is 3-Ply)
-The new Cooper Discoverer ST Pro. Looks like a hybrid mud/AT but it is pricey.
-The KM2's but they are also pricy and probably heavy.
-Just do the KO2's AT and live with the fact that they may not be great off road.
-What am I not thinking about?
BTW. When I do go off road, I will likely be in CO for a vacation, or in East TX on red clay sand at Bardwell.
Any feedback would be greatly appreciated.
Old December 28th, 2015, 02:13 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Heard good things about these tires, but no personal experience.
I really like the STT MAXX i have on my Disco. I would look hard at these for the 90 next time around.
KM2s are really heavy. I like mine. I want to say they are E range. I air them down to 13 and the sidewalls dont bulge all that much. I would probably go 255 if I got these again.
Depending on what you are doing, KO2s are a hella good tire in most conditions
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old December 28th, 2015, 02:26 PM
Maybe I am a Luddite thee KM's are easily one of the best tires ever made. I am runningd KM 255's in a D load range. I need to replace them as they are cracking from age. I have been really happy with these tires, E load range is a bit much for a Defender
Old January 1st, 2016, 11:08 AM
Originally Posted by RickM View Post
I would love some feedback here as I am struggling with what I want to do. I am running 285/75/16's on steel rims that have a bit wider backspacing. They don't rub so I am good. They are currently the older MTR's. I need to replace them and struggling with what to do. I want a tire capable of doing some good off roading, but to be honest, drive this truck on pretty days in Dallas. Here is my list. -Goodyear Duratrac E ratings (although the sidewall ply has me concerned, as I think it is 3-Ply) -The new Cooper Discoverer ST Pro. Looks like a hybrid mud/AT but it is pricey. -The KM2's but they are also pricy and probably heavy. -Just do the KO2's AT and live with the fact that they may not be great off road. -What am I not thinking about? BTW. When I do go off road, I will likely be in CO for a vacation, or in East TX on red clay sand at Bardwell. Any feedback would be greatly appreciated.
285/75/16 Cooper STT Pro
Old January 1st, 2016, 11:15 AM
looks good
Old January 2nd, 2016, 10:14 PM
RickM
Rick Mabus
95 D-90 ST
Lostchord. Those look awesome. How do they drive. Do they feel heavy?
Old January 3rd, 2016, 07:25 PM
thanks
i don't know yet - story for another thread on another day
will post back once i can answer that question
------ Follow up post added January 3rd, 2016 07:25 PM ------
Originally Posted by rover4x4 View Post
looks good
thanks!
Old January 6th, 2016, 10:25 PM
RickM
Rick Mabus
95 D-90 ST
I have some stt's waiting on me. Planning on getting them mounted tomorrow.
Old January 8th, 2016, 10:38 AM
RickM
Rick Mabus
95 D-90 ST
Well. I have about 1 mile now on my Cooper STT's. Theses dudes were pricey. But I can truly say I was surprised at how much quieter they are than the old style MTR's that came off the truck. They look sweet also.
Old January 8th, 2016, 04:58 PM
redline_r
Ridwan
1986/Land Rover 110
Photos!
Old January 23rd, 2016, 11:54 AM
no 'heavy' feeling and nice road manners
that said, they're on a truck that caps out at 70 mph and has some play in the steering
Old May 4th, 2016, 11:05 PM
LI90
Jim
1986 90 xmod
I'm just about to pull the trigger on 275/75/18's - thoughts anyone? Definitely nicer/cleaner on a 90 then 285/65's right?
Jim
Old May 5th, 2016, 12:47 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Jim
Just my opinion but if you are going for the mall crawlin' JK look 18" or even 20" rims on a D90 will do the trick. Literally every JK at my local mall is running them.
**The opinion I just expressed is solely my opinion and not those of Defender Source or its members, any likeness or similarity to the opinions (on JKesque low profile tire/rim combos) of other members is purely coincidental and does not constitute me being a "hater."
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
