Tire Size OME Lift? - Defender Source
Old March 3rd, 2010, 08:42 AM
Ronanmd1
Jason
1997 D90 HS2.8
Tire Size OME Lift?
Hey guys - Will 255/85/16s rub with an OME 2" lift?
ason
Old March 3rd, 2010, 08:59 AM
mine rub the rear fenders at full tuck but I think its because of my rear links. You can run the steering stops out for a much improved turning radius
Old March 3rd, 2010, 09:58 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Nothing rubbed on mine when I had the 255's on. Used an OME 2" lift as well. Didn't make any adjustments to the steering stops either.
Old March 3rd, 2010, 03:40 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
can I suggest the RYM springs RR4-2 fronts and RR3-2 Rears. Great 2" lift springs and ride better then stock. Perfect for that size tire too. We have run 285's with those springs and love them.
Legend in My Own Mind.
Old March 4th, 2010, 01:26 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Randy, may I ask what you recommend for a small lift on a RRC? A buddy of mine recently picked one up. It won't see much off-road use, but he wants to give it a small lift.
Old March 4th, 2010, 08:38 AM
Ronanmd1
Jason
1997 D90 HS2.8
Thanks guys...
Jason
Old March 4th, 2010, 11:35 AM
Spring lifts should not affect tire clearance as they should not control maximum travel. That is controlled by the bump stops and the shocks. The lift springs just make it harder to compress, but it can still happen under the right circumstances.
255/85/16 fits fine stock. They will just touch at the top in the rear in full articulation against the bump stops.
Old March 4th, 2010, 12:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I shot you a PM...
Old March 4th, 2010, 12:26 PM
RRC rear springs in the front, OME MD springs in the back.
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
Tire size and lift jdb3760 Misc. Chit-Chat 5 November 6th, 2006 04:55 PM
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
