Tire size help for Boost wheels on D110 - Defender Source
Old August 21st, 2011, 12:25 PM
silverlight's Avatar
silverlight
Geoff
1993 Defender 110 NAS
Hi - I just got a D110 NAS and have purchased a set of 16x7 Boost wheels from a fellow board member. Was going to order a set of BFG KM2's to put on the rims, but wanted to make sure I get the right size. I'm currently running stock steel wheels and the tires are BFG AT's (dont know what version) with sizing of 265/75/16. So would appreciate suggestions on sizing as I don't know the differences between the stock wheels and the Boosts (I admit I like the look of the 265's vs something like 235 stock, but recognize that's personal opinion).
Thanks!
ID:	41268   Click image for larger version
Old August 21st, 2011, 12:55 PM
Truck looks good. Why do you want to go from the ATs to KM2s?
Old August 21st, 2011, 02:18 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
265 will fit but sometimes rub on the radius arms unless you use spacers. You can also adjust your bump stops so that this doesn't happen.
Land Rover 110
Old August 21st, 2011, 02:53 PM
How about a paint job instead
Old August 21st, 2011, 03:37 PM
specops1526's Avatar
specops1526
Beluga '97 90
As much as I like Boost wheels, I don't think alloys look right on NAS 110s. The truck has a certain look to it and alloys sometimes say something else...stick with those steel wheels. They look good and are hard to come by. Plus, with alloys on those axles, you can't put center caps on which then makes the alloys look incomplete. If you don't like the white, change the color and put some KM2s on.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old August 21st, 2011, 04:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Huh?
Old August 21st, 2011, 04:22 PM
silverlight
Geoff
Well that's a good point on the center caps.... I had figured I'd just try them for a bit and see how they look, and if I really didn't like them, then re-sell them. I have liked them on 110's (including NAS) that are different colors, but can't recall seeing a photo of a white NAS 110 with them (perhaps for a reason?). Curious why the other installs of these wheels on 110's (including a couple NAS) had the center cap on? I think one or two may have been ECR builds.
Old August 21st, 2011, 04:55 PM
bjf's Avatar
bjf
barry f
94 ST #395
You can put the center caps on if you use spacers.
I assume ECR trucks get updated axles which don't need spacers.
I say keep the wheels you have.
Old August 21st, 2011, 06:45 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We typically install wheel spacers to make the alloys look right for customers. Helps with turning radius as well as the alloys are a narrower offset than your ANR1534PM rims. Our favorite rims on a 110... are exactly what you have, the stock D130/NAS110 steel wheel.
Email:
Old August 21st, 2011, 07:20 PM
a suggestion. Put your current at's on the alloys and the km2's on the steels. Off road use will destroy the expensive boost's quickly
Old August 21st, 2011, 07:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
Do the alloys not fit without spacers if you update axles? Why do they fit on a 90 and look correct but not a 110?
Old August 21st, 2011, 08:26 PM
Capt Milks's Avatar
Capt Milks
All of the wheels will fit it is just a personal preference on what looks good. The NAS 110 came with the white steel wheels, some people like it the way it came. But it does limit you on tire size if you stick with the steel wheels.
Land Rover 110
Old August 22nd, 2011, 01:39 PM
silverlight
Geoff
Thanks all for the feedback and ideas (and clarifications!)
Cheers!
Old August 22nd, 2011, 01:43 PM
Old August 22nd, 2011, 01:51 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Daniel who is on the board (INI88) might be interested in the A/T's. He is in the city as well. He has some Boost with Km2's if you want to see them. His are a little bigger than what you are looking for I think.
Old August 22nd, 2011, 01:55 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Geoffrey lets get together. We can swap rims/tire real quick if you want to check out the look!
Old August 22nd, 2011, 01:58 PM
tjfslaughter
thomas
Burbon
With your Photochop skills you dont even need to meet up....
We need to do another NYC meet up anyway.
Old August 22nd, 2011, 02:05 PM
I forget what size you have but I remember my 285/75s are smaller. If you guys end up meeting up let me know...need to get the fan back to you anyway!!
I have Boosts w/KM2s in 285/75 R16s with spacers so you could try that as well.
Old August 22nd, 2011, 02:11 PM
tjfslaughter
thomas
Burbon
Might be best to meet up at my house. Got the tools and a fridge full of frosty beverages.
------ Follow up post added August 22nd, 2011 03:21 PM ------
huh?
x2??
Old August 22nd, 2011, 03:43 PM
ini88's Avatar
ini88
Daniel Marcello
I don't need the fan. pay me for it or get it back to me when you can. I have a HUGE radiator now.
110, boost, d110, tire, wheel, wheels
tire size for 16" stock steel wheels Sandt Defender Technical Discussions 9 August 18th, 2011 11:16 PM
D110 rim size? Robbie Donaldson Misc. Chit-Chat 17 August 6th, 2005 11:18 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
