Tire size choices for 15x10 - Defender Source
Old May 3rd, 2013, 01:35 AM
CDeWan
Clay DeWan
5.3L beastie
O.k. may pick up a set of 15x10 Beadlock rims. What tire sizes are available that are bigger than a 33 that would fit so 34 and 35 but in metric and how wide can I go? I know it is a really broad question so just high level. I am currently running 255/85/16s on stock alloys and have a 3 inch lift so the tires look a bit undersized not to mention I stuck some wheel spacers behind the rims.
Old May 3rd, 2013, 02:19 AM
CDeWan
Clay DeWan
5.3L beastie
tires
Jeff,
Thanks you. I have been seeing 35x12.5X15. I think a 315 is the same as a 35 help?
Old May 3rd, 2013, 05:42 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I usually go to National Tire and Wheel http://www.ntwonline.com/All-Tires.html and use their tire search tool. It is easy to use and will give you an idea of what your choices are.
Old May 3rd, 2013, 11:05 AM
I guess the definition of "fit" should be defined.... Any of the 34 or 35" tires need some mods to clear (trimming and/or compression travel limits).
Old May 3rd, 2013, 11:21 AM
CDeWan
Clay DeWan
5.3L beastie
fit
True - I do have a set up for the travel and wheel well fit but very good point.
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
