Tire Size - Defender Source
Old May 13th, 2005, 11:28 PM
kmg99
Kirsten G
1994 D90
Tire Size
Will 285/75 tires fit a stock heidht D90 without clearance issues?
Thanks!
Old May 14th, 2005, 12:10 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Yes... very minimal rubbing under full stuffing in the wheel well though.
Chris von C
[/size]
Old May 14th, 2005, 12:24 AM
Nigel
Ted Constantine
I am running 285 MTR with ome spring. I don't know that age of the spring as they came on the vehicle but I do get contact with the control arms at full lock on both sides. Not that big a deal but I scares the people that have borrowed the defender.
Old May 14th, 2005, 02:41 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Nigel, a simple 17mm (or 19mm?) open wrench can helo you out...there's a bolt that is on the front side of the swivel housing that protrudes to hit the axle housing...make it protrude more so that the turning radius will lessen and the tires won't rub - both sides need change...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
tire size mfreeman17 Defender Technical Discussions 8 April 18th, 2004 12:16 PM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
