tire size - Defender Source
Old April 10th, 2004, 08:57 PM
mfreeman17
Mark Freeman
94 D90
tire size
I have a 97 d90 with a 2" old man emu lift. I was running 265 75 16 BF muds and am looking to run a BF AT 285 75 16 or the bigger 315 75 16. Here is the question: I know that running a 35" tire will off set the stock gearing ratios, and that ideally the gears ought to be changed to accomodate. What happens if I don't. In other words, what are the cons, or problems I will encounter by running a 34.8"X12.3" tire on stock gears, etc.?
Old April 10th, 2004, 09:07 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
On the street Your transmission will be down shifting all the time trying to find the right gearing, and forget about your 4th gear.
Off road you will not have any compression gearing and you have to use your brakes every time you go down hill.
World traveler
Old April 10th, 2004, 09:13 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
I have 285's on my stock d90 and have no problems.
Old April 10th, 2004, 09:21 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I too run 285, BFG KM MTs. Used to be on stock lift and now on OME 2" lift. No issues except every once in a while I has a slider fender rub under articulation but main because of the offset steels.
You might want too also consider 255/85s. Slightly taller tire and a hair narrower than the 285s.
Chris von C
[/size]
Old April 10th, 2004, 11:05 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I just came back from a trip to go wheeling. It was 110 miles of interstate before we got to the trails.
I am running 35x12.50 tires and as of yet the 4.10 gears aren't in so I drove with the 3.54 stock gearing.
Fifth gear is useless unless you have a very good tail wind. And I am serious, we had a 10 mph headwind and of the whole 110 miles I used fifth gear for about three miles. ( downhill only )
So this means running aprox. 60 mph at 2800 rps. I can't wait till the 4.10 gears are in.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old April 11th, 2004, 01:58 PM
Mark, just like Yousef said, with an Auto tranny diving on road the trans will always be trying to find the right gear. If you have a manual trans like Richard or Chris you will be fine as you can hold 1st gear a little more to compensate for the tires but an auto will just be lost.
Old April 11th, 2004, 03:34 PM
RoverWorld
Francesco Di Tommaso
D90 Td5 Soft Top MY02
Is anyone with 285's and 4.1 gear? I wish to hear a feedback.
Francesco
www.roverworld.com
Old April 12th, 2004, 08:45 PM
lobster's Avatar
lobster
Rob Goodall
1995 D90
I am running 35's with 4.75 gears. The tach sits at 3000 when I am in 5th gear going down the highway at 62mph
1995 D90 ST
1999 Super V8
Old April 18th, 2004, 12:16 PM
scoloco's Avatar
scoloco
'94 D90 ST
I dont have that combo yet, but that is what I'm shooting for.
tire
Stock Tire Carrier Bolt size Joe P Defender Technical Discussions 4 May 9th, 2005 06:03 PM
MTR Tire Size for OME lift??? TurkD90 Defender Technical Discussions 14 December 5th, 2004 08:44 PM
Actual Tire size? revor Defender Technical Discussions 8 July 8th, 2004 10:10 AM
Boost alloy tire size? ftaube Defender Technical Discussions 6 February 3rd, 2004 11:25 PM
maximum tire size snuffer Defender Technical Discussions 14 November 13th, 2003 09:15 PM
