tire pressures with a 300 TDi - Defender Source
Old May 27th, 2007, 07:10 PM
cdb
Clark Bowen
I was checking the tire air pressures and bringing them to NAS factory settings when I realized that my front tire pressures are probably too low for the highway with a 300 TDi, winch and heavy bumper. Book says 28 lbs. I run 30. I figure I have about 350 more lbs on the front end than a stock D 90 now.
Any thoughts?
Also I applied the QuietCar coating and re-installed the bonnet. I'll post pictures and comments after it has fully cured (7 days).
Clark
Old May 27th, 2007, 08:21 PM
I just look at the max pressure on the tire and go with that for road use..
Old May 27th, 2007, 09:58 PM
Cirbo's Avatar
Cirbo
Jim C.
Ouch!
Old May 27th, 2007, 10:24 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Originally Posted by Cirbo
Ouch!
X2, thats about the worst possible way to figure correct tire pressure. Must ride like you have square wheels too.
Old May 27th, 2007, 11:54 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Any thoughts?
Clark
What pressure are you using on rear axle ?
- Charles Eames
Old May 28th, 2007, 12:06 AM
cdb
Clark Bowen
38 lbs
Old May 28th, 2007, 08:54 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I run 28 all round with 265 BFG AT.
I'm one of the guy that still don't get why
you need a greater pressure in the rear ...
- Charles Eames
Old May 28th, 2007, 11:51 AM
cdb
Clark Bowen
300 TDi tire pressures
JFD wrote:
"I run 28 all round with 265 BFG AT.
you need a greater pressure in the rear"
Actually, I wonder why too. How does it handle on the road versus the stock pressures? How about tire wear? Are you running a diesel?
Clark
Old May 28th, 2007, 11:55 AM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
I ran 65psi most of my recent 4000+ mile trip, when I lowered it to 35psi for a smoother ride off road and did not put it back to 65psi my fuel mileage slipped almost 1.5 mpg. I drive a 300 tdi diesel with just about all the accessories you can have so it it pretty heavy, plus all my gear. Ride was really good on the hwy, but rather harsh off road. To each his own I guess.
Old May 28th, 2007, 02:10 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Damned, that's a lot of pressure , 65 psi....
Clark, I do run a Tdi also.
- Charles Eames
Old May 29th, 2007, 07:42 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I think pressure is different on each setup and tire combo. YOu should really be checking your pressure by chalking a tire and running it.. THen seeing if its over or under inflated for your rig.. I usually run 35-45lbs in mine
Legend in My Own Mind.
Old May 29th, 2007, 08:17 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
28lbs front and rear, 10lbs off road
3rd low and BOOT IT
Old May 29th, 2007, 10:22 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
7lb front, 5lb rear.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 29th, 2007, 05:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
right pressure for post climbing ???
- Charles Eames
Old May 29th, 2007, 10:12 PM
Shane@EVS
Roverhybrids
Different tires sizes and load ranges require different pressures.
28psi IMHO is much to low for the street on a D90
For your tires Clark I think 40-45 front and ~35 rear.
You can do the chalk thing too ,but I don't think it will give a true estimate because your tires may be too wide for your wheels.
Old May 29th, 2007, 11:21 PM
cdb
Clark Bowen
tire pressures on 300 TDi
Thanks Shane.
I'm astonished at the range of pressures various people run on the street.
Tire companies are always saying that 10% under or over inflation leads to multiple heat and wear problems, so that would indicate there is a near ideal for my motor/winch configuration and tire size. Makes me wonder how LR come up with 28/38.
A brake shop I used in Eureka insisted upon very different pressures and they were like your numbers. He got it from some chart - I think.
So I'll give those numbers a try and see what happens. It does feel like I'm getting some tire "roll" on sharp turns at my current pressures - 30/38 - but it feels more like it is the rear that is buckling under a bit.
Clark
Old May 30th, 2007, 01:39 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Mine is always a balance between rough ride and bad handling. My D90 is pretty fully loaded weight wise and running the 255/85's I run 30 all around, ish.
Old May 30th, 2007, 03:38 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I Run around 35 psi front & read on my 200 tdi with 7.50 16 radials but it really does depend on load & tyre size
Mike Hammond
Old May 30th, 2007, 09:58 AM
oldgreentrucks's Avatar
oldgreentrucks
Jim Pace
Several combinations work well in the 30-40 psi range. Larger tires need less pressure to support an equal load as stock tire. Heavier loads require increased pressure for any size tire. Chalking is good but actually measuring the tread depth (outer, middle , and inner) @ X psi and checking at the next oil change is the best way to monitor tire wear for driving in individual conditions. Having said that I run 30/30 in my stock tire D90, and 25/25 oversize Series III. FYI when acquiring the Series III it had 85psi, 85! because that was max listed on the Load range E side wall. Brought that down to 25 and drives like a different truck.
Why +psi in the rear? For year manufactures have suggested increase pressure in the rear for most all vehicles. Increased pressure provides increased stability, to a point, which makes the rear of the vehicle more stable. MFGs like stable vehicles (just ask Chevy about the corvair)! This pressure offset enhances the understeer charachteristics of the vehicle, again which MFGs and their legal counsel like. Squaring up the pressures (same f/r) usually makes for a better handling vehicle and better tire wear.
Jim
Old May 31st, 2007, 01:46 PM
mikeslandrover
Mike Hammond
I dare say there is some sort of graph for trye pressure against load but whether it's a straight line form 0 load/0 pressure up to max load and max pressure is beyond me
Mike Hammond
300 tdi, tdi, tire
300 Tdi A/C question... roverboy Defender Technical Discussions 3 September 17th, 2005 02:15 PM
MTL prices in Mass, 300 Tdi oil artm Defender Technical Discussions 4 September 10th, 2004 11:45 AM
