Tire Mounting Options for my Tithonus - Page 2 - Defender Source
Old January 7th, 2014, 08:26 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Originally Posted by cgalpin View Post
Why can't you put a spacer slightly thicker than the overlapping piece of top between the body and the tire carrier and bolt it through the body below the top? Tie the backing plate into the cage for strength. You'd probably need a spacer at the bottom as well, but nbd.
Maybe I'm not seeing what you're talking about but I don't think a spacer would help. The top bracket of the Mantec mounts right at the capping:
My gel top comes down just south of the capping. To make it work, I'd have to either mount it through the top (which definitely doesn't make sense) or notch the top. In the end, I think notching a 2"x3" square from the gel top is crappy but an acceptable compromise to have a nice spare carrier that has a very stock appearance. The RockWare carrier, nice as it is, just isn't an option for me. I much prefer the look of the bare crossmember.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 7th, 2014, 08:34 PM
Weld a tab below the bracket and put the spacer there with the bolts through it instead of the current position in the capping. The bracket would be up against the top or very close to it and I don't think would look odd. There would be some torque on it but it's sideways more than in/out.
Originally Posted by pendy
I'm here for the D's
Old January 7th, 2014, 09:58 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I don't actually know what make of tire carrier I have (bought it used from a board member) but this is how mine is mounted with out having to drill the top. The only real problem is it is mounted a little low so it is very close to the pintle hitch. Hope this helps.
ID:	87500   Click image for larger version
ID:	87502   Click image for larger version
Old January 7th, 2014, 10:16 PM
A can of Fix-Flat and a rabbits foot should do it.
Old January 7th, 2014, 11:09 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Here is a is a pic of a carrier I made a few years ago. Was designed to sit below the soft top & high enough to clear the pintle hitch. The top mounting plate was 1/4" thick and if the mounting bolts were countersunk it may tuck under the FG top. I also had a brace on the inside to transfer the weight to the tub side.
Still have all the drawings for the cut pieces etc...
Old January 8th, 2014, 11:16 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
problem solved…
Old January 8th, 2014, 11:31 PM
Originally Posted by Mybluett View Post
problem solved…
Looks stronger than the truck itself.
Make?
Cost?
Availability?
Old January 9th, 2014, 12:47 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Make?
Cost?
Availability?
Answers:
Kaymar (Australian)
$more than I'd like ($850)
We can supply - (looking at lead times now)
mount, tire, tithonus
Wanted Instructions On Mounting Stock NA D90 Tire Carrier wadaman Defender Technical Discussions 1 April 15th, 2011 03:52 PM
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
Stock tire Carrier Mounting Bracket Joe P Wanted 2 September 8th, 2005 08:11 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
