Tire Inflation Systems - use my current scuba tanks?? - Defender Source
Old September 10th, 2009, 11:09 AM
advnirvana
Andy B
94 D90 NAS
Been looking at an alternative to the available portable air tank systems for my Defender 90. I did a quick search with limited info.
I am an avid scuba diver and always have full tanks on hand (both aluminum and high pressure steel). Seems that many of the portable tanks systems are aluminum scuba tanks.
Does it not make sense to use one of my spare scuba regulators (first stage) and add an attachment to the low pressure port to inflate my tires? The regulator is designed to resist freeze up and there are a few aftermarket attachments for air inflation. It also already has a guage. I will be using air instead of CO2.
Am I missing something or will this work?
Thanks in advance.
Andy
94 Defender 90
07 BMW GSA Adventure
Old September 10th, 2009, 11:59 AM
I think the problem with normal air tanks is the volatility... CO2 is only at 1800 psi, where air can be 4500 psi. CO2 bottles also have a relieve valve, and it will not shoot across the room if it falls over.
I have Powertanks, and really like them, they have been very useful. I would recommend just purchasing one of them. There are a few knock-offs, and I think that they work well. A few people have cobbled together a CO2 system by getting a used CO2 tank from a restaurant supply or a welding shop, then buying a regulator off eBay. The Powertank regulator, in my opinion, is far superior and provides up to 200 psi, and does not freeze up.
Old September 10th, 2009, 03:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I agree with Scott. No need to pay for an expensive tank. Go to your local welding shop and you just lease it basically. When its empty, you drop it off and pick up a full one.
I have a Power Tank and when I take it to get filled, I some times have to wait 30= min to have it filled. The tank then just goes in a bag anyway and you never tell what brand it is anyway.
Legend in My Own Mind.
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
ST rear tire carrier / tailgate rattling... DiscoDino Defender Technical Discussions 9 December 3rd, 2005 06:50 AM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
