Tire help - Defender Source
Old April 7th, 2015, 09:46 PM
Defenderdude
Jason
1983 Defender 110
Tire help
I know what tires I am going to get I'm going to get some BFG AT K/O 235/85/16. But the question I have is I know the rim size is 16 but that's all, I am looking at paddock and they have 16x6.5 to 16x10 what size do I need I know the offset is 8mm stock but there are still four options left. please help.
Old April 7th, 2015, 10:29 PM
Defenderdude
Jason
1983 Defender 110
No not factory there some kind of off brand tire, and I have steel wheels.
Old April 8th, 2015, 07:16 PM
Defenderdude
Jason
1983 Defender 110
I'm just trying to figure out what the number after the rim size is, and if it is even important.
Old April 8th, 2015, 07:21 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
*wheel size are shown as 16x7 or something of the like. What number are you referring to?
Old April 8th, 2015, 07:38 PM
Blake's Avatar
Blake
Blake
1997 90 Wolf
16x6.5 or 16x10 is referring to a 16" diameter rim with a width of 6.5" or 10", etc. If you look up the tire you're looking at and find the manufacturer's spec sheet it specifies the minimum and maximum rim width for the tire.
For example I have stock wolf rims that are 16x6.5 and I put on bfg km2 255/85r16 tires, they list a minimum rim width of 6.5" maximum 8". See attached.
Old April 8th, 2015, 07:53 PM
Defenderdude
Jason
1983 Defender 110
Ahhh thanks a lot Blake that help was going to get the 235/85R16 BFG All Terrain T/A KO and rims on paddock now I know what to get 16x6 rims thanks for the help
Old April 8th, 2015, 08:14 PM
A Wolf rim is probably the best choice for that size. Good width and offset.
Old April 8th, 2015, 08:42 PM
Defenderdude
Jason
1983 Defender 110
Offset on wolf is 20mm, I thought the stock offset was 8mm?
tire
Heavy duty swing away tire spare tire carrier $200 Jbirdlott For Sale - Parts 10 May 7th, 2013 01:44 PM
PARTS PURGE: 35s, tire chains, cubby, rover tech coat, 110 glass, rear tire carrier nathanwind For Sale - Parts 37 June 19th, 2012 10:28 PM
Mantec tire carrier vs. TD5 style rear door for 33" tire? motap Defender Technical Discussions 8 January 30th, 2010 09:54 AM
Rockware Winch Bumper, Tire Chains, Tire Carrier e90miller For Sale - Parts 10 November 13th, 2009 05:08 PM
can't change my tire???? help ttegt Defender Technical Discussions 17 June 17th, 2008 01:02 AM
