Tire fit? - Defender Source
Old January 31st, 2005, 10:55 PM
Zeke
Jay Desautels
Tire fit?
I am interested in larger MT's...probably 255 85 16's. I have a '97 Station wagon with stock suspension. Do I need a lift or will these tuck under? Also, will my stock rear tire mount be able to support the added (if any) weight?
Old January 31st, 2005, 11:20 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
you're probably going to need a lift. Do you have anything that may weigh down the truck i.e. after market bumper, winch... these will definitely make it tough to fit the tire. I have the tire with what started as a 2" lift (OME 751 front and 764 rear) but with my bumper, winch and full exterior roll bar I lost almost a inch. The tires fit real well, I would like to get back my inch but it would be only for aesthetics. I like the tire a lot, there aren't too many companies in the US that make a 33"-34" tire in that width. Just get the tires and do the lift, you'll be happy in the long run.
Old February 1st, 2005, 10:33 AM
ronward's Avatar
ronward
Redsrover
None - sadly
I agree. I have the 751/764 OME setup on my 1997 ST and run BFG MT's in 255/85. No rubbing and I have plenty of lift. Great tire, lose a little power from a dead stop, but not much.
Anything is possible, with the right tools...
Old February 1st, 2005, 11:01 AM
They will fit fine.
Spring lifts do NOT affect tire clearance......
Old February 1st, 2005, 11:08 AM
ronward's Avatar
ronward
Redsrover
None - sadly
How's that?
Old February 1st, 2005, 12:51 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Originally Posted by Red90
They will fit fine.
AH WHAT! I think the Blue labal has gotten to you!
tire
Tire options after OME lift... Rover- Girl Misc. Chit-Chat 23 February 12th, 2008 05:06 PM
12.5" tire on a 7" rim? souza Defender Technical Discussions 16 August 19th, 2005 04:04 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
hard spare tire cover - will this fit a D90 rim? jaherring Defender Technical Discussions 2 October 11th, 2004 01:16 PM
