Tire, coolant and other new owner questions - Defender Source
Old October 22nd, 2004, 12:07 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
OK, just got home with the new baby (White '94 ST #601) and I noticed some curious things on the 1000 mile trip. For about the first 600 miles, whenever I would stop I'd notice a pool of coolant underneath. Looks like it's coming from the expansion tank, but it was hard to tell if it was the overflow tube, or the lid, or the seam around the middle leaking. I just want to make sure it's not normal. My '69 Series IIa would occaisionally do things like that and it didn't have a "leak". The level is now OK, so it didn't just run dry
2nd, It has BFG MT 285/75R16's and when I got home (7700 ft elevation) I thought they would have about 75 psi in them since I came from sea level. Well they have 20 psi in there, so was the PO running 5-10 psi in them? They didn't look aired down at all when I picked up the truck, and now they still aren't bulging as much as the 265's on the Disco at 35 psi. I've searched on this one and it seems that people run these anywhere from 20 to 50 psi. So, I guess comfort is the big factor? Comparing it to my old Series which felt like getting hit in the back with a shovel while driving a tractor, the Defender rides really smoothly, at least for a UPS truck
3rd, I'm moving across the country to CT and have to drive the cars in about a week, so I'll be doing the 60,000 mile maintenance this weekend. Anything else to get it ready for the long drive? It has the LT77S transmission, what's the reason everyone wants to update to the R380?
Dave
Old October 22nd, 2004, 01:54 PM
KeithD
Keith Duckett
90 V8 Import
I run 285/75s at 30psi back and front. They are very comfy off road at 12 psi but not so sensible on road...
Old October 24th, 2004, 03:27 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
LT77S had a problem with lubrication to the rear output shaft and the input gear in the transfer box. The splines waer prematurely. This is easily cured by fitting a cross drilled input gear if ou catch it early enough before wear takes a hold on the splines. Lt77 works for me...
Mike Hammond
coolant, new owner, tire
