Tire chains - Defender Source
Old November 18th, 2011, 05:35 PM
Naplm00
Matthew
Tire chains
Ive seen the links for the RUD grip chains, but after reading this article on how the adjusters break so easily I am not convinced.
Any other suggestions?
http://www.expeditionr.com/2010/03/0...chains-review/
235/85-16
Old November 18th, 2011, 05:58 PM
carlosz's Avatar
carlosz
Carlos
I have used snow chains on 18 wheelers while traveling in canada and with all due honesty I dont remember having issues.
some 15yrs ago I purchased a used car where the owner had recently moved from arizouna, long story short he had a set of "traction cables" I loved them, you can drive up to 40 mph on wires vrs 15 mph on chains, unlike chains they do not strech nor do they loosen forcing you to stop often.
since then I have had interest in purchsing a couple sets for the rover and the other cars but honestly aside from a blown trans back in the blizzard of 2009/2010 I have never had an issue driving in snow.
Iwould use cables before chains.
Old November 18th, 2011, 07:09 PM
grnrvrs's Avatar
grnrvrs
Paul
88
That guy is an idiot.
Originally Posted by Naplm00 View Post
1970 SIIA 88, Sold
For on road use, it does not matter much. Any chain should stand up as long as you stay off dry roads. Regular cable chains are probably easiest to use.
For off road, get a proper chain. V-bar ladder style is cheap, easy to install and works great. A good solid 8 mm chain set will last a lifetime.
The Ruds are "OK" but they are pretty light with small chain. Not really enough bite for off road use. I don't see them as easier to put on. The one guy that wheels with them uses them on the front. The idea is they won't bite as hard and it reduces the chance of breaking the weak ass front drivetrain. They "might" be better in steering as well although I'm not sure we have seen evidence.
For the next 4 months all my off roading will be with chains on.
http://www.red90.ca/photos/land-rove...0_2397.JPG.php
Old November 18th, 2011, 07:28 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've never used Rud chains, but I've used the standard v-bar chains a lot (at times 4 or 5 months out of the year) and if properly installed never had them come off. The only time I've had them come off was when I was rushing and didn't stop to adjust them after driving a bit.
These are the ones I'm talking about, http://www.tirechain.com/VBAR.htm
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 18th, 2011, 11:11 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Pewag.
-Jeff
I've heard a lot of good things about Pewag. What's the model of chain to get? Running 285/75 KM2s but I couldn't find a fit.
Old November 19th, 2011, 09:10 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Page 13 of the Traction Chain catalog lists several styles in that size. There may be others.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 19th, 2011, 01:47 PM
Naplm00
Matthew
I think of me sticking with the diamond style chain the ladder seems more for off road and a pain to install. I saw the scc whitestar alloy looked nice and is affordable. Thule make a high tech set fir about 40$ more per pair
Old November 19th, 2011, 03:38 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I have and have used the RUD chains. Haven't had any problems if they are adjusted correctly. I have noticed that they can be tightened up after a few rotations in the wheels. They have worked as well as any other chains I have seen.
Old November 19th, 2011, 03:50 PM
Frank84
Frank Battersby
95 D90
Seen many RUD tire chains brake - but keep in mind that it is usually just the rubber tensioner that breaks. A few rubber bungee cords will take the place. However, I've had good luck with Whitestar Diamand Pattern chains from JC Whitney without any breaks. I do carry extra rubber bungee cords and quick links just in case though.
'95 Soft Top
'89 Classic Tdi
Old November 19th, 2011, 05:58 PM
Ladder chains go on quicker in my experience.
If for on road, just get some cables. Quick and easy to fit and smoother to run.
Old November 19th, 2011, 09:41 PM
chris snell
Chris Snell
87 Ex-MOD 110
Now I just need to find a reputable Pewag dealer. Where did you guys buy yours?
tire
265/75/16 Tire Chains Brand New e90miller For Sale - Parts 0 July 6th, 2010 02:50 PM
Rockware(Warn 8274) style Winch Bumper, Tire Chains Set and Aluminum Dash Cowl MTC280 e90miller For Sale - Parts 11 January 29th, 2010 06:24 PM
Rockware Winch Bumper, Tire Chains, Tire Carrier e90miller For Sale - Parts 10 November 13th, 2009 05:08 PM
Tire Chains bcourtney For Sale - Parts 0 February 2nd, 2009 03:55 PM
Brand New RUD Grip 4x4 Tire Chains Steve Friedman For Sale - Parts 0 February 23rd, 2006 04:41 PM
